Coming up to 48hrs after working on the front suspension and replacing the front LH strut and all its not well.
Quick recap, the front end of the car was dropping (both sides pretty equally) when I purchased the car. When I stripped the suspension out I found that the LHS was the original and the RHS was an Arnott replacement build 11/15. I have no record from the PO of, if or when he replaced the RHS, but guess it was around 35-40k ago based on the dates on the Carfax.
So the car is dropping as follow at arpund 48 hrs standing:
LHF (New remanufactured Arnott) 7-10mm
RHF (35-40k old Arnott) 20-25mm
LHR (OEM 20k old) 0-3mm (I think it just settled slightly after my initial measurement)
RHR (Original) 5mm
I sprayed the RHF with soapwater and cant see any leaks, to be honest I think the LHF dropping is the sway bar pulling it down when the RHF is losing air.
I have ordered a remanufactured Arnott for the RHF, should be here by the weekend.
In the meantime, I will start the car again and pump up the suspension and disengage the front sway bar and disconnect the battery and measure again over the next day or so.
