John I’m with countvohn and the rest of the guys.
There are just too many red flags here. A warped block but it’s still running with no cel. Most of us are mechanical guys and even some of us are techs. What I can say is its not adding up. If there was enough oil leaking that was comming from the heads you wouldn’t be able to drive long before you were out of oil or had a low oil pressure issue. Let alone having a warped block. You can’t eye ball a block and tell if it’s warped or not and if it was warped so bad you could see by eye it sure as heck isn’t going to be running
Just isn’t adding up
Still if you need an engine there is a local guy that has a 8k motor with a new starter and fresh cleaned set of injectors. I think he wants 8200. Let me know I can see if he is still selling it. He bought it for a project and it’s just sitting.
