I totally agree Saki. But JHM have my stock clutch as an exchange item. Regarding a bent shaft, I have already thought of that and checked the original gearbox and the new one I have fitted. The problem has been there since the first fit. Regarding bleeding the hydraulics, I have replaced both cylinders and bled the system several times BUT I would say I still have a feeling its clutch release movement related. I have cut a hole in the bell housing so can see the clutch movement and the release bearing is moving a good 1/4 inch. I can also see that everything is running perfectly true. Nobody has been able to tell me how much movement I need to clear the friction plate. I have put the whole assembly on the press and I believe it needs nearer 9mm (3/8) to get things clear but how do I achieve that?
