Didn’t see this till now.
Interesting! There is a TON more front rebound at the stiffest setting compared to the rear. You can also see the digressive curve, so ride quality is probably quite nice on the JRZ’s to boot.
On full stiff, the front favors rebound, and the rear favors bump. But on the softer settings, the reverse is true. The front struts are valved for a lot more spring than the rears. What rates did you end up going with?
RE: alignment - not much to play with on a street car (toe/camber/caster). I recall your previous alignment settings to be pretty solid. Again, it depends on what you are trying to address. Me personally, I’m gunning for -2.5 to -3 front camber, -1 to -1.5 rear camber next year, with 1mm front toe out, 0mm rear toe. I find there is way not enough trailing throttle rotation, and the car totally stinks on corner entry. Those #'s should loosen it right up
I’m not worried about it being “too loose” bc let’s face it, it’s awd and 55/45 weight distribution. FWIW most proper front heavy awd/ff track cars actually end up running rear toe OUT to help with the trailing throttle rotation. I’m not going that crazy until I try something more neutral first.
