Hold the presses!!!
I was looking at my rear suspension today and noticed something I had not noticed before!
The rear motion ratio is closer to 0.9–just like a macpherson strut.
The rear spring acts directly on the same pickup point as the knuckle. This means that as the knuckle moves up and down, the movement for the spring perch will be very nearly the same.
http://www.airsociety.net/wp-content/uploads/2013/12/accuair-b8-audi-air-suspension-ride-e-level-bagged-airsociety-011.jpg
In the image above, you can see that the lower spring perch is sitting on what looks like a lower arm. Actually, this is not an arm at all. Notice that the spring perch is directly connected to the knuckle–the knuckle is actually extended inwards to be the lower spring perch! There is only 1 pivot point here–this is the outer most pivot point on the knuckle. AKA, this suspension is directly acting on the pick up point. This makes the motion ratio much closer to 1:1. (Read: the back end of the B8 is geometrically stiff by design). This means that you do not actually need a spring rate that is sky high for the back of this car (unlike a typical multi-link rear suspension would).
The information on spring rate/wheel rate I had obtained from a Stasis vendor was incorrect, thus making my original motion ratio calculations wrong. In reality, the rear motion ratio is more like 0.9, and the front remains to be around 0.65.
This explains why a more “track” worthy coilover like the H&R RSS has rates such as 690f, 380r. When you factor in the motion ratios, the resulting wheel rates end up being 291f/380r–the resulting wheel rates makes way more sense for this platform.
