Do you really care about that extra weight?
Imo this is what i would buy. Even with weight reduction, she is a big girl and needs the capacity. Your pads will last longer too. Until you get real rotor cooling i would aim for as much thermal capacity as i can
I don’t. I point it out in relation to the ultra light JHM rotors I had which cracked (the way that I was using them). Weight close to the center matters even less. The type V if I can get it should run cooler, make my pads last longer, and extend the rotor life. I’m willing to give this a go and not blow $12k on the CCM-R ceramics just yet, which will be a full 10 pounds lighter than the type V. If I get the full performance here this may work out long term.
Never tried it myself but cryo treating your new rotors is an option.
Preparing to switch to type 3 rotor.
http://uploads.tapatalk-cdn.com/20160127/9bbb3c68ee115b8f3bf36265d5189288.jpg
Nice! Those look awesome.
Sent from my iPhone using Tapatalk
Nice fingernails…I mean rotors
True story the only car part I’ve ever touched is the steering wheel.
Wow that’s impressive.
There’s a ton more rotor veins in there than the usual disc. Sure looks a lot more than 48 veins!
72 vein. The etching pattern is supposed to be pad-abrasive for superior initial bite and better ability to modulate-off. I think they might be 4 pounds lighter. The photo below has the aluminum hat the and hardware fasteners, which are probably about 2 pounds.
Looking good!any impressions?
The old rotor rings were 19 lbs without the hat, and I wore them under 31mm.
Not too bad. The weight difference isnt going to harm anything either. Clean looking
Short review: these are supercar brakes. My lap times dropped about 2 whole seconds at Laguna and I’m in the 1:43 range even with traffic. Highly recommend.
Brembo CCM-R rotor. It is literally $6000 vs $500 for a type 3 ring. The type 3 lasts about 20-24 track days. I estimate this would last 80-95 track days, so essentially the life of the car unless they were damaged.
How much lighter if any are they?
The brembo type 3 rotors were 4 pounds lighter than the brembo street rotor.
Thats a big deal right there. 4lbs off is a difference you can feel in the cars performance.
