I’m stumped.
The “issue” is on the driver’s side. First item I did was swap the D1S bulbs to see if the problem moved to the passenger side with the bulb. It did not. Next item, swap the ballasts to see if the issue moves to the passenger side. It did not. So now we know both the new D1S bulbs and both the new ballasts work perfectly…on the passenger side. Which tells me so do the old parts I removed. I don’t mind having two sets of ballasts and bulbs. What’s killing me is the issue I can’t resolve.
When I first swap the bulbs, the driver’s side fires up but then goes out and I get the “dipped headlight” warning. When I swap the ballasts, same thing – fires up then goes out and the warning light pops up.
When I cleared the codes yesterday, directly after installing the new parts, there was indeed 4 or 5 fault codes. Same ones listed in an AZ thread I was referencing. Then I vag’d the ballasts to talk to the ECU etc, checked the codes one last time and still had the issue.
Fast forward to today, I do my swap with the parts but the weird thing is even though I’m getting the error on my DIS it’s not coming up when I scan with the vag cable?? I even took video to prove this is accurate.
Another odd thing, at least to me, is each time I open a door or the hood etc, the driver’s side D1S bulb that I’m having an issue with is flickering like a mofo. I took video of this as well.
So, I start the car and I instantly get the main headlight warning on the DIS. I turn the headlight knob to auto or “on” and instantly get the dipped headlight error on the DIS. Yet nothing pops up in vcds when I scan for fault codes under xenon 55 whatever.
P.S. I can take the bumper cover off and remove the headlights in 20 minutes flat. I can’t line that mother up the way I want if my life depended on it. FML.
P.P.S On a positive note I might have lost 5lbs of water weight while in the garage.
