^Yea forgot to mention the O2 sensors about leaded fuel. But what are the advantages/reasons that is so prominent in performance situations and even aircraft motors (low lead etc). Just curious as I know little on the topic. Guess I need to google more.
On the EtOH fuel, how do you view that in the Audi’s and other performance based cars vs fuel from the name band premium places?
I think the Count once said that the ethonal does not affect us at all because it is made up for with timing ro something like that. We have all 10% ethonal in Chicagoland but up in Wisconsin they have a lot of no-ethonal gas but it’s only 92 octane. I notice no difference with either
94 with ethanol is better. moar faster is moar better.
although the negative effects of ethanol on fuel efficiency are annoying, I really don’t care relative to better performance I’m afforded (vs buying no ethanol 91). The ‘drying’ effects of ethanol on the other hand that prove to be a problem with carb engines may also have some kind of long term effect on car engines…but I haven’t seen anything about this. Everyone used to worry that the ethanol would dry out seals and lead to leaks of various sorts. Not sure how legit that fear is.
Interesting about the shell 91 Saki, unfortunately that’s not an option down here. Everyone in TN/AL/KY for the most part is 87/89/93 and every name brand station I’ve been always has the sticker “all gas may contain up to 10% ethanol”
The concern about ethanol in marine applications is that it absorbs the water that accumulates in the fuel tanks causing missfires and all the things that water in gas would usually cause. We had this issue with our boat. Filled it up at a non-marine gas station off the highway which was 10% ethanol, and 2-3 weeks later we started having issues with it caused by the gas. Not a big deal really - just had to add a couple cans of seafoam. Marine gas is so expensive. A good 40-50 cents higher than regular, and it’s always 89 octane.
I don’t see how that idea will apply to carbeurated engines. How the eff do you spell carborated?
I think you’re talking about the same thing…it draws water out of the fuel and seperates it. It also draws moisture out of just about everything rubber.
strong hydrogen bonds on each, they attract… ever pour 1 measure of pure etoh into 1 measure of pure h2O? You don’t get 2 measures of fluid once mixed. The water ethanol interaction is very interesting.
as far as a fuel e10 v pure dino its a wash imho, the etoh provides better cylinder cooling (allowing more timing advance) the dino stuff has better energy content
Carburetor. That’s how my phone wants to spell it. Although my phone also wants to spell tire so what does it know lol
+1 with saki about the petrol up here. 91 No ethanol = further, 94 = faster.
I agonised for a while over 91 vs 93 tune as the Shell 91 is the most convenient for me. But then if I wanted convenient or economical, I would’ve got another TDI.
It attracts water actually. And I noticed, when I ran E85 that I went through O2 sensors just as quickly as I did whilst running leaded fuels. Yep I said whilst.
