First off I’d like to say hello, I am new to this forum and was directed over here by a member of audiworld. Maybe you all could help me out with a small problem I’m having…
So I just got my 07 rs4 back from the dealership today, they broke the whole engine down, new piston rings, full carbon clean. Installed my JHM lightweight flywheel, stg 3 clutch, Intake Spacers and LW Crank pulley. A few questions regarding how the engine should run.
Since I am still breaking everything in I have been “taking it easy” on her, still pushing it hard but not to redline. When I am driving along at a constant speed every 30 seconds- 1 minute I feel almost like the power cuts out for half a second. Enough to where the momentum will make your head bob forward ever so slightly and the RPMS drop. Has anyone ever herd of this. My tech was saying it could be a combo of the LW pulley and LW flywheel that is making that happen but I’d like to think differently since the clutch is engaged and there is forward movement.
Also, the car is having trouble staying idle… it will never stall itself out but if I just let it sit there idling for 2 minutes the rpms will drop to the point where you think its going to stall then you here the big woosh and the engine rev up past 1100 and drop back to normal. This will go on and on.
Any thoughts? Could it be bad gas? The dealer filled it up at their pump which was not labeled with any octane rating… I have no idea, I’m stumped.
She defiantly pulls like a SOB now, that magic 5000+ RPM zone is heavenly now, can’t wait for everything to be broken in. Also, if you drive it hard none of those symptoms are present… only if you are following a car an remain at a constant speed, in 2nd gear it happens around 2700-3k…
Any thoughts, chime in.
