I’m at work lol.
I don’t know where the noise is coming from seeing as the only way I can make the noise occur is by driving it and when I’m in the driver’s seat, it just makes a sound with no clear indication of where it’s coming from.
I seriously don’t think it has anything to do with the brakes though. I have a lot of experience with brakes and I’ve never heard brakes make a noise like this. I’m thinking more something that might be flexing due to load from a dead stop. The second the car is moving, it stops and doesn’t do it until the next time I start moving from a dead stop.
Noise could be wheel bearing, clutch, possible drive belt, though I doubt it’s the belt. Maybe a tech could verify if this car can be put on a lift either asym, or symetrical lift, and with the suspension unloaded, fire up the car and replicate the condition/engage the clutch. then have a tech pin point the origin of the noise. this will be the quickest way to find it.
Get your girlfriend or friend to start the car from a stop while you stand or walk beside it. See if you can locate it. Do it in an underground garage so you don’t freeze to death.
I guess I’d be in as well. I might have to work from 8pm to 1pm Saturday to Sunday though so maybe around 11am or so. Will need to take a nap from 4-6pm if I do have to go into work for 8pm.
I was trying to say I have no shudder. I have some chatter once in a while if I’m not super careful which can sometimes feel like shudder but it’s just the 6-puck clutch doing it’s grabby thing.
