So just went and did a few early morning runs to log some data…
Temp 48
BP 30.2
Humidity 82%
DA 750ish…
So left the house and drove about 5-6 miles to warm the car up and once the oil was about 160 I did a few runs… Given it was on the street most were only a few gears and I tried a 1-2 roll 2-3 roll, 3 gear punch and I did try one launch put the car wheel hopped very bad given the cold ground so I got out of it and then back into it…
So first one my IAT’s were in the teens and 20’s! lol Gotta love cold dense air! I rolled out of the light and punched it at about 2500RPM and the car hit hard and pulled very strong… Unfortunately, I bypassed 6% of the boost up to 6000 RPM and then about 10% to redline as I was up against the max targeted boost the whole time… I’m 100% sure this is a result of the pulley as I’d never hit the target before which makes sense… Timing was good on the mid and upper 20’s(this is on 104 tune and GT260+ fuel) Little retard in 1 of the 2 cylinders I’ve logged but nothing major. Air mass was nearly 1500 by redline…
Second one was a punch from a roll in 2 and similar results from a bypass standpoint. Tiiming was similar with a little less pull and IAT’s were in the mid 30’s by now… Both target and actual boost were higher by about 60hpa which is because I was in 2 not 1.
Third one basically same results with no timing pull, little higher target and actual boost again given the gear and IAT’s were upper 30’s to very low 40’s… hpa was up about another 50 points…
Fourth was from a dig and as mentioned I got out of it and back into it since I was hoping violently… lol The encouraging thing here is I had almost no bypass until I got out of it then a ton and then when I got back into it was 3-4% until 6000RPM than it got to about 9% to redline…
So overall getting some bypass but I kind of expected it but everything else seems to be ok on these few short passes… Safe enough that I feel ok making some actual passes and going all the way through 4th. Still not sure if it’s a big event at Thompson today but I’ll probably just bite the bullet and go anyway and at least make a pass or two… Will just be a ton of cars, lots of waiting(which the car doesn’t like) and probably only 2 passes before racing actually starts… If not Sunday should be better but warmer so we’ll see I might do both days…
If anyone wants the logs let me know and I’ll be glad to email them as I have no problem sharing…
Jeff, Have you logged you car in great air and are you getting bypass at all?
