Saki the 2.0 x level is not where the issue was its with the car running above 1.1 on average idle and under load. I logged more than just this plot.
You are correct, the issue was 2 vac leaks. Not the tune. The tuen only had input to this in that it runs closer to the upper limits, and it actually probably helped me detect the vac leaks earlier than i normally would have.
Excuse my overreacting on the tune, I have talked with Dan and the guys at JHM about this and I apologized to them for my initial reaction which was half the reason I was upset about the tune. The other half was of course as you know the issue with the SAI, but true to their word, the guys stepped up, got me a fix, and I am no longer looking at bleeding money for somethign I shouldn’t have to.
I hope you understand when a dealer and a tech and others tell you that its lean because of a tune, and/or the SAI needs to be replaced at a cost of $1200, and/or engines are blowing up because of going lean, you tend to get a bit worried. I certainly wish I could have filtered all the advice a bit better.
Anyways enough of that, lets get back to hating each other! haha
