So I grabbed a quick log of what the maf should look like at each rpm for idle with 18% throttle and then 100% throttle - So for idle you’re clearly WAY off. I know one bad maf can cause both to read wrong from what I have seen in the past.
I guess I should change the other maf cause it makes no sense at all. It has to be that I’m overthinking it
Hey guys I was using my bs scanner and I swapped the engine computer from right to left
I noticed that the code changed from maf b to a
Wont let me post other picture from some reason but It changed from maf b to a high circuit so I’m starting to think maybe the computer is bad.
I’ll check with the Ross tech when my laptop is alive but it’s starting to seem like the computers
It changed sides
Here’s a scan of it with the computers swapped
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
07-Control Head – Status: OK 0000
09-Cent. Elect. – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
15-Airbags – Status: OK 0000
55-Headlight Range – Status: Malfunction 0010
56-Radio – Status: OK 0000
61-Battery Regul. – Status: OK 0000
65-Tire Pressure – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
77-Telephone – Status: Malfunction 0010
Address 01: Engine Labels:. 07L-910-552-BSM1.clb
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L JHM/V1 OCT9 ª0040
Revision: 59H09— Serial number:
Coding: 01050009190F0160
Shop #: WSC 13622 410 403014
VCID: 221DE3E888C6D8ABD17-8076
VINID: 9D19577891161077800C11C200FD5CFBA5
5 Faults Found:
000259 - Mass Air Flow Sensor (G70)
P0103 - 001 - Signal too High - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:26:14
Freeze Frame:
RPM: 614 /min
Load: 27.8 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 44.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.827 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:26:14
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Temperature: 6.0°C
Voltage: 12.319 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:17
Freeze Frame:
RPM: 1142 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: -40.0°C
Voltage: 11.557 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:49
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Temperature: 6.0°C
Voltage: 12.192 V
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:57
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 6.0°C
Voltage: 12.192 V
Readiness: 0110 1101
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0050
Revision: --H01— Serial number: 0086056
Coding: 0000002
VCID: 2F3B1ADCCB1465C34E9-807A
1 Fault Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:10
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 214.0
Temperature: 62.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
Shop #: WSC 02325 785 00200
VCID: 313F1CA4DD20733358D-8064
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 147
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:51
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x0028
Hex Value: 0x0198
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000481449
Coding: 0000007
Shop #: WSC 06402 785 00200
VCID: 6393A6ECD75C91A39A1-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
No fault code found.
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 393FP067500038
Coding: 0010003
Shop #: WSC 00000 000 08192
VCID: 323D13A8D826482B217-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000467789
Subsystem 3 - Serial number: 0110.07.060000000100011443ÿ
Subsystem 4 - Serial number: 011443ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000030142529
Coding: 0524330
VCID: 5BE39E0CEF2CA963D21-800E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115121
Shop #: WSC 02335 785 00200
VCID: 303919A0D62A7A3B573-8064
Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
3 Faults Found:
02745 - Bulb for Daytime Running Light; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:00
02746 - Bulb for Daytime Running Light; Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:00
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 270BF2FCEFE43D83869-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F2029645
Shop #: WSC 00000 000 00000
VCID: 2809F1C0EEFA32FB8F3-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 147
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:09
Address 11: Engine II Labels:. 07L-910-552-BSM2.clb
1 Fault Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:25:30
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Temperature: 6.0°C
Voltage: 12.319 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7G AIRBAG AUDI8RH29 0400
Revision: 01H29000 Serial number: 003BMD000K0Q
Coding: 0014151
Shop #: WSC 08159 444 85931
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME107F3E2FI
Subsystem 3 - Serial number: 6342CSME107E082B5
Subsystem 4 - Serial number: 6352QSME0F2E263BU
Subsystem 5 - Serial number: 6362QSME1037084FG
Subsystem 6 - Serial number: 63734SME0E69353DB
Subsystem 7 - Serial number: 6381VSME041343133
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026061890037
Coding: 0012141
Shop #: WSC 02323 785 00200
VCID: 6695BFF8246EE48B7DF-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 980 Q
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5H337R576
Coding: 2129263
Shop #: WSC 08101 067 57207
VCID: 2313E6EC97DCD1A3DA1-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B067038018
Coding: F5D5DEF7307A06
Shop #: WSC 02334 785 00200
VCID: 6C81CDD03A82DEDB2BB-8038
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FACE4CD4083B388D-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 381FK067502811
Shop #: WSC 08101 444 83282
VCID: 2E0507D8CC1E6CCB45F-807A
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0051947
Shop #: WSC 02327 785 00200
VCID: 2C010DD0FA021EDB6BB-8078
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 82026955640000
Coding: 4618301
Shop #: WSC 28594 002 104857
Component: LIN BACKUP HORN H05 1501
2 Faults Found:
02103 - Control Module 2 for Vehicle Electrical System (J520)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 254
Reset counter: 147
Mileage: 116987 km
Time Indication: 0
Date: 2006.03.15
Time: 13:32:21
02735 - Bulb for Tail Light 3; Right
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 147
Mileage: 141849 km
Time Indication: 0
Date: 2022.06.21
Time: 12:00:28
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000008417
Coding: 0000026
VCID: 2517F8F499E82F93B45-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000035163
Coding: 0012014
VCID: 5EE59718FC3EBC4BB5F-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04—
Coding: 0008022
Shop #: WSC 02324 785 00200
VCID: 1F1BEA1CBBB4F543FE9-804A
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290FF4C4F5F00BF390D-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
007 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 146504 km
Time Indication: 0
Date: 2022.09.18
Time: 15:59:09
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394G+067661758
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000058452
Shop #: WSC 22129 444 52429
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 2409200358
Coding: 344630393135313035432056413032343039323030333538
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700015537
Coding: 0062422
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 18
Mileage: 141931 km
Time Indication: 0
Date: 2022.07.11
Time: 18:20:57
Freeze Frame:
(no units): 0.0
Voltage: 11.80 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606230018
Shop #: WSC 12336 024 394758
VCID: 343115B02232461B33B-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J6620TQ
Coding: 1000204
VCID: 5DE79014F138A753AC5-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220619205014
Coding: 0021306
Shop #: WSC 131071 1023 2097151
VCID: 270BF2FCE3E43D83869-8072
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005086687
Coding: 0000000
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 147
Mileage: 146500 km
Time Indication: 0
Date: 2022.09.18
Time: 15:04:11
End----------(Elapsed Time: 02:03, VBatt start/end: 12.3V/12.1V)-----------
Hey guys swapping the ecu made a difference Now it’s saying 3g/s
Car seems to be running fine. I’ll let you know what happens tomorrow I’ll be driving 50 miles out to my school.
A good but bad victory… Good you fixed it bad to find out the ECU was damaged. This is a good road map for future issues like this. GREAT work.
Thank you and the car is running excellent. I’m thinking of getting the ecu fixed to be a spare if something happens like this again
Turned out it wasn’t the second ecu. I swapped that nothing happened so I started playing around. I put back the second one and tried swapping the first one and that did it
ECU #! is the main ECU if there is an error generally it will be in this ECU as ECU 2 is basically the slave ECU.
