VC gasket leaks may not show up on the garage floor due to the skid plate. I dont think there’s a test for the PCV. But if your consumption increased at the same time the valve was replaced last year then its probably faulty.
From everything I’ve read… A ring job (sounds dirty…lol) is a bad idea for 4.2 S4/RS4 engines. You probably can’t even find a mechanic to do it and offer any sort of guarantee. But maybe someone will chime in and bring up an example of a successful ring replacement.
You should do what saki suggested and watch for smoke at start up. If no smoke go in for a compression test. If failed or borderline (under 130ea iirc) get leakdown tested and borescoped.
