replacement starter battery
Deka is a major battery manufacturer as well. I was under the impression that deka was the actual battery that was getting rebranded
East Penn is the manufacturer
Deka is their line
Braille is someone they supply, among others (sears etc). They’re gigantic.
http://tapatalk.imageshack.com/v2/14/12/10/4353bf300da223316c7d79222a05c894.jpg
Apparently the S4 has a water cooled alternator that is $1300 to replace and is a pain in the ass to get to. This battery also mitigates the expiration of that part by taking 80% of the load off of it.
Nice!
awesome battery! how are you going to secure it in the factory location? also if you have never taken out your battery before, I believe its the sports diff ecu that is attached to the bracket that you need to remove first.
Spot weld a small plate in there. Height and width are the same, but it’s about 4" less in length.
Just jam it in there with cardboard shims, pes style
http://i945.photobucket.com/albums/ad291/04ultrasprt/2005%20S4/IMG_2185-1-1.jpg
If I’m not mistaken one must also change the cars battery cable clamps to the through bolt type since the battery has flush poles with bolt holes for holding the car’s cables?
Braille has special posts that you screw on to make them like normal terminals.
I have left-over posts from when I had Braille/Deka LWB on my STi… if anyone needs them.
http://tapatalk.imageshack.com/v2/14/12/12/60c70290baff44ae4952c9a5ef4ce057.jpg
That’s awesome.
Is it just me or is the battery in the op $2300 dollars?
Also has anyone in a cold state tried the one that wolf posted?
If it’s starting his 4.2 S4 for over a year that’s pretty impressive. Although I don’t know where he lives…
I’m in North Carolina…no one I know of in a cold state has picked one up. Someone should try it…
Very nice - you just lost the equivalent of a small child out of the back!
Is it $2300 retail. Amazon Prime sells it for $1550 free shipping, and in some states no tax. They also get you the part in 24-48 hours after you click buy.
The trick with these batteries if it’s very cold is to get some current flowing you through them. So you’d turn on the headlights for 15 seconds. Then turn them off. Then turnover the car.
You can always keep one of these in the car for emergency. I bought one the other day. It holds the charge for 1 year, and can start up to 20 cars on one charge! I tried it the other day on some of my dads cars that have been sitting for months with dead batts, they all jumped like nothing.
Walmart has them on sale right now for $60, Amazon also has it but no expected ship date.
http://www.walmart.com/ip/Jump-and-Go-Portable-Power-Supply-Red/39097777
Witchcraft
This battery continues to work flawlessly. I leave the car for 3-4 weeks at a time and it fires right up.
