^^ Ditto!
Ok more fun with graphs. And yes, an 11 second pass would be nice! One thing I’ve noticed is a “soft” shift in comparison to others. I believe it’s the smaller clutch pack (2, 4, and 6) whereas the larger (1, 3, 5 and 7) is snappy in comparison. So possible clutch wear on my end or even a possibly weak main pressure solenoid for that gear set. It’s not super obvious but I did notice the other day. Ben’s car is far younger, LOL. I’d like to swap in a more aggressive clutch pack and apparently, you only need to run adaptation at a few select mileage points to adjust to the additional friction capability.
But back to graphs!
Going to post a few from my last visit to the drag strip. The main difference is I’m NOT using a fan pack. Cliff notes version, it was pretty stable. Ambient temps were as high as 78 and for the most part, the ATF fluid stayed in the 70’s with the clutch temps often reaching 20 degrees higher before cooling down at the end of the run. I made sure to do two things. First, I went to the furthest exit at the end of the run so the car had more airflow for a longer period of time. The second thing I did was run the a/c fans for a bit to help mediate temps. With the fan pack, they kick on at about 80C so you never have to think about it. Now if I just had a tuner that could maybe link trans temps to fan speed…hmm. When the ATF temps hit 80C, maybe turn the fans on, like 20%. Should do the trick without turning the a/c on.
Some graphs. These are large but I’ve included the graph color chart on the left. Again, this is the RMR trans cooler kit WITHOUT a fan pack.
This one was labeled drag run 2 (made nine passes that day).
The thermostat generally stabilizes the temp at around 68-70C. I’ve started out at 71C (red/yellow line), sitting in the staging line. Max, at the end of the run is 77C and within seconds, it begins to cool down again. By the time I make it to the pits, it’s back down to 72 degrees. One note, not all the graphs are on the same axis. The green line is the manual transmission fluid on the gearbox side and it’s peak temp is also 77C but the way it’s graphed makes it look like it’s much hotter. It isn’t.
Here’s a closer view of the same drag run with more detail.
Now just imagine if you’re running the OEM cooler and it’s being “cooled” by 200 degree F (93C) coolant. The ATF fluid is already in the 90 degree range and the clutch would be 20 degrees hotter minimum. Not good!
Here’s drag run six of the night. Temps stay pretty stable. This was at 4 or 5pm in the afternoon when ambient air temps were at their peak.
I did not make all runs back to back to back. Just impossible. Once you circle back around, there’s a line which varies in length so sometimes you get to run within 10 minutes, sometimes it’s a half hour wait. You then spend time idling with five or six cars in front of you (at best!) as you slowly creep up to the start line waiting for your turn to run. Not ideal but it is what it is.
So how bout city driving? I did an experiment on Thursday. Ambient temperatures were 72 degrees which, for my tests, is idea as it’s unlikely the fans will come on unless you’re idling for an extended period of time. The VCDS does not allow you to log fan speed AND transmission temperatures. I need to see if I can request that. So it’s one or the other.
First graph is cold start and a drive downtown from my house. So same drive as the OEM cooler graph posted earlier. This time I threw in some city driving at the end though. The important part is after 900 seconds, the ATF temp with the RMR cooler is identical to the OEM cooler. So warmup time is exactly the same. And again, the gearbox temp graph is on another axis so it appears hotter but it’s peak temp is 65C.
Torture test time…I logged from a hot start meaning I’d driven the car for a bit, it was warmed up, I began logging, then turned the car on. I drove around in the city, stoplight to stoplight with no issues. Temps stayed in the 70 degree range, no a/c fans on.
One really interesting aspect of the above graph is clutch temperature. The graph above is actually two graphs stacked on top of one and other. The bottom one, the red line is the clutch temp. See the spikes? Look at the white graph. That’s vehicle speed. Note the spikes come from when the car is stopped but in gear.
So far so good. I’ll continue testing but it looks like it’ll work as-is. I do believe, had I kept driving around, slowly, from stoplight to stoplight, the temps would have continued to rise into the 80C range but still damn safe and then some. Now if it’s moderately hot, you’ll probably turn the a/c on and the fans will kick in and the measured ATF temps will drop quickly.
Awesome!
The fan pack on the RMR cooler only turns on when you click on the AC?
Nada, with the fan pack it’s automatic. There’s a thermal switch which completes the circuit when temps hit 80c so it’s completely automatic.
It without the fan pack, in heavy traffic and mild temps, the atf temp has the potential to go higher than 80c unless the car’s fans are running. I position the cooler to be just in front of the a/c condenser so air is pulled through more efficiently than if I’d left it where it sits with the fan pack. If I left it in that position without the fan pack, air may go around the core instead of through it.
So with your climate, you’d benefit more having the fan pack. Me? During the summer the a/c is never turned off from May through October, lol.
So am i right in thinking that with the fan pack on when your stuck in traffic in gear we will not get the spikes of high temps unlike your getting with no fan packs ?
Does the default kit come with the fan pack? Sorry, I can’t recall!
These graphs are great! It would be helpful maybe if in your top post you listed the average trans temps of OEM vs RMR and the delta between the two for quick access of the following (graphs make it a bit hard to quickly decipher for users):
Race
Street (aggresive)
Daily (start/stop(
Yes we have the fan pack on our kit !
That is correct. The fan pack basically prevents the temps from getting much above 80 Celsius in slow traffic, mild temps. If it’s hot out, you’re most likely running the a/c. If it’s cold out, typical Brit winter weather, the fan pack will most likely never come on. It’s a very small range. If you’re moving at speed, the fan pack won’t come on and isn’t needed. It’s a precaution for low speed driving, like getting stuck on the motorway due to an accident or congestion where you’re creeping along for an hour.
I have yet to get the transmission fluid seriously hot without the fan pack. I’ve been running without the fans for almost two months now. Winters here vary wildly but generally I’m seeing daytime temps between 50F and 80F degrees. It was 79F today and 55F last Sunday. Not hot enough to run the a/c but I haven’t gotten stuck in serious traffic yet either. City driving, stoplight to stoplight, wasn’t an issue at all.
Yes, the standard “premium” kit has the fan pack, wiring harness, all the bells and whistles.
The “evo” kit won’t have the fan pack or the wiring harness but will have everything else the premium kit has.
I posted one graph, where I did the exact same drive, car already warmed up, and there was about a 20 degree difference between the two, normal driving. In the canyons, “hooning” it, it was even greater, about 40 degrees. I got up to 90C with the fan pack on a 95F degree day, I’d expect about 10 degrees lower without. This is on tight roads where you never hit redline in third gear. It’s all 1st and 2nd gear corners with some small straights where you get into third then hard on the brakes again.
On a road course, you’d get a ton of high speed airflow on every straight and I’d imagine it’d make a world of difference over the OEM cooler which would always be tied in to the coolant temps.
This is a graph where I’m hitting the canyons, a run called the twisted sisters for good reason. It was very hot that day, somewhere around 95F to 97F (36C). This is with the fan pack. White is rpm and red is ATF temp.
Here’s a “normal” drive of highway and city driving, exact same stretch of road, where you can see the difference between the OEM cooler and the RMR cooler.
Unfortunately I don’t have the OEM cooler when hitting the canyons mostly because I was logging other parameters for the stage 2 tune. Needless to say, I could not use LC as the trans temps were in the 120C to 130C range in ambient temps which were COOLER than my run with the RMR cooler. I’m actually hitting some interesting roads tomorrow on my way out to a freelance gig in Fredericksburg so it’ll be a good opportunity to do some logging in the mountains in mild temps.
Heya, so basically, you’re seeing a 20 degree difference with the RMR cooler, in most conditions across the board?
That would be correct. Shocking really.
Ok more fun with graphs!
Let me set the scene. Yesterday I had to drive out to the middle of nowhere Mexico for a freelance shoot at a brewery. It was, perhaps, one of the most beautiful days ever. Temps in the low to mid-70’s Fahrenheit and not a cloud in the sky. The road leading to the middle of nowhere is a fairly undulating “fast” road. Nothing tight at all and it’s mostly high speed. I’d hammer it out and back which would enable me to get a different look at how the cooler performed.
Best laid plans.
An eighth of the way in on the testing road, I ran into construction. This would be the norm for the next 20 miles. It wasn’t just any construction, it went from a two lane to a one lane with extended stop periods while traffic heading the other direction came through. They even set up stoplights but those only added to the time sitting.
Great. Plan out the window. I get to my freelance assignment and find out they forgot to call and cancel as the power went out. Really??? Ok. Beautiful day and I saw some choice spots for car photos. All is not lost.
I decided to see just how hot I could get the transmission. I logged the entire trip back. The log is over 1.6 hours in length. Seriously.
I started out at the brewery. Beautiful building, I’ll use that as a backdrop. I positioned the car and left it running while I got out and shot photos. This lasted for a good half hour.
Once under way, the first half was nice and fast, no traffic, no construction. It was all high speed so there was a lot of airflow. Predictably, I was always running about 66C on the transmission temps, 80 on the clutch and gearbox.
Once I hit the scenic spot, I pulled over, left the log and the car running and proceeded to shoot. I found several locations and never turned the car off.
To my surprise, the temps remained in the cool range, only rising to 74 degrees after an extended period of time. It mostly stayed in the 60 degree Celsius range.
Hitting the road again, I hammered it until I came to the construction zones and invariably, other cars. At each stopping point, I purposely left the car in gear to watch and log the trans/clutch temps to see what they did. Both rose, slowly, to a point. Typically, sitting, car in D, the clutch would rise quickly into the 90 degree C range, but would stop around 94C max. And it’d stay there. Far different from the OEM cooler which would continue to rise into the 100’s. Once moving, the temperatures would all rapidly drop. The manual gear oil would drop in temp with every stop (predictably) so there’s definitely some heat transfer happening between the ATF and MTF side.
Overall, I was expecting temperatures to get much hotter when stopped or idling in D mode. It didn’t happen. It may be due to the Setrab cooler’s size and being able to radiate heat to the surrounding air. When I was shooting, I did not hear the car’s fans running. My typical oil temps were in the 222F range, fairly consistently. The car always runs hotter in mild and cold temps. If I could just get it to run at 206F all the time…I’ll save that for the next mod.
Graphs! This is the entire 1.63 hours. You can click on any of these and make them larger.
Here’s a closeup of the graph color guide.
Here’s a closer view of the entire 1.63 hour graph.
This is when I first started the car back up and was positioning it to take photos at the brewery. Notice the car is mostly at idle (white line on the top graph). The temps come down as the fluid circulates through the cooler and they stay almost completely steady the whole time. The a/c is NOT on.
Here’s a closeup of the “fast” section. Note, white is rpm on top, with white on the bottom being vehicle speed. Like I said, in Mexico. The only downside is it was mostly a 5-7 gear situation. Not a lot of acceleration to redline through all the gears. These are tiny “B” roads as they call them in Europe and quite rough in spots.
Here’s the “scenic” section. I was flying, came upon a few good spots to shoot, pulled over and left the car running.
This is a closer view of the construction section where I had to come to a complete stop, leaving the car in gear.
This is a slightly expanded view of a section of the above graph so you can see more detail. Overall, I’m completely happy with the way the cooler performed without the fan.
That’s great news looks like its doing the job without the fan packs ! It just show you that by it not running past the coolant in the rad and just having it run through a separate cooler is enough to keep the temps lower and more stable. Great work there getting all the graphs together its very interesting and i love the little story to go with it sounds like you had fun lol !
I’m really kind of surprised but I’ll continue to monitor in different situations. This would be a very “American” situation but I can see the trans temps getting higher if you were to say get stuck on the highway while commuting in between San Antonio and Austin where you’re creeping along really slowly and stopping for long periods frequently. The fan pack is for the worst case scenarios and at the drag strip too. Its 100% foolproof.
I was helping an S5 owner with a trans cooler a while back. He’d already sourced his own Setrab core, different size, with a fan pack as well, but was using my cross bar to mount it. His idea was to hook it up to a digital gauge made by Aeroforce and use it to set a different temp for the fan pack to come on. I don’t think he’s gotten back around to working on it again but it was a neat idea and I may actually pick up one of those gauges regardless. https://www.aeroforcetech.com/products_interceptor.html
The system I use is automatic and has a thermal core which connects the circuit when temps get above 80C causing the fans to come on . With the gauge, you could theoretically set it at an even lower temp. There are no thermal triggers, like the one I use, which trigger at a lower temperature. 80C is as low as they go as they’re mostly designed for oil systems.
Wow that sounds ace and a good idea, but what would be the advantage of the Aeroforcetech apart from setting it lower than 80c how much lower would you want to go ? Is there an optimum temp for the ATF and is it lower than 80c if not then what you have already does the job does it not ? Unless there is more things you can do with the Aeroforcetech like pre set temps in stages depending on what your doing in the car ie drag strip or tight and twisty’s or traffic jam then all you would do is select a temp you want it to be at.
As for the testing your doing now i get what your saying if your stuck in that sort of traffic then yes you might see temps rise up, for that it would be great like you said to have the oem fans cut in to bring it back down, but saying that so far so good and its a surprise how well its doing so you never know it might surprise you with this situation !
Yeah it does a ton of stuff. One idea, for the drag guys, would be to just have the fans come on when in the pits. Could work with the road race guys too. Could cool down the half liter of fluid in the cooler and be ready for the next run. But you could set them to come on at 70C instead, providing that much more of a cushion when at the track and not moving. Optimally, you’re probably looking at 60-90C. The clutch seems to like 80C range. Rarely see it drop below that.
I kinda wonder if I can configure the car’s fans to come on with it. Might have to reach out to them.
Yeah it sounds good to me if it can do all these things it would be a big bonus for the drag strip, stuck in traffic and even track as like you say 70c would give you an extra 10c cooler running temps !!
There must be a way to get the fans to come on and off with this Aeroforcetech well worth looking in to, see what you can find out.
The new Evo kits are now live and ready to be ordered. They’re simpler to install, have fewer components and are less expensive to boot. No sacrifice in quality!. Doing a flash sale group buy limited to the first ten kits and it’ll save you $100 off of the normal price. Contact me for details!
Hi Ape,
Being a member of A5OC for years and not getting any good info or answers at problems there except costs a lot… Searching for a transcooler and info on the DL501 brought me to here…
I own a 2011 Audi S5 Sportback CAKA and somewhere I read that you where checking into a transcooler for the S5… I wanted to see what your thoughts are on the following:
Getting myself ready to do a Mechatronics rebuild (P179D) and spending lots of time diving in to the heat issues and failures of it, made me wonder why it does not have a dedicated oil cooler. (I have the P179D error and logging livedata with Carista (Yes the last update will give you live data on trans temp) on the transmission temp, the car makes me sweat to get it over 90c. (I have cleared the fault past startup of the car, but might be a hidden small limp/save mode is still active))
So my thoughts at the moment:
Transmission:
Change oil flow to dedicated oil cooler from Hel or Setrab to RS5 style right lower grill location
(This will decouple the oil cooling from the front radiator/ heat exchanger)
Engine:
Change oil flow to dedicated oil cooler from Hel or Setrab to RS5 style left lower grill location
Supercharger:
Supercharger oil flow to optional ADS cooler
Engine Coolant:
Change OEM radiator/ heat exchanger flow so the coolant can flow extra through the old oil loop
The idea came up that making the oil system separate:
- Will drop the loads on the front radiator, lowering the supercharger cooling IAT temperatures
- More cooling for the DL501 to make it more reliable
- Better engine cooling
- Less risk of mixing coolant with engine oil
Has anyone had any experience on this mods or thoughts to swap out.
(Typing this out makes me feel like the Mad Scientist they give at work might be true)
I have searched a way to DM it to you, not found a way… Maybe cause I am a new puppy member haha
