Nice launch! What tracks are you guys running at in Michigan?
vast burned a very important bridge, and suddenly all the vast cars got real slow
Not so coincidentally, all the JHM cars took over around the same time.
Funny how that worked out.
Milan if you are near Detroit and then earlier in the fall, s6atron organized a day at the ubly dragway.
SHOStprS4:
Actually, I have spent alot of time at Ubly. (I grew up about 10 miles away from there.) I have to say I have never seen an Audi there…mainly American made cars. How many of you guys get out to Ubly?
sakimano:
SHOStprS4:
Ubly is nice. Your right tho. If you don’t have a domestic they look at you like your dropping someone off at the track. We used to take a lot of the cars from W2W there. Seened to be there track of choise. Milan is good but lapeer is fun. Its more laid back. WAY less tech ntho no screen board but still a fun track.
hahaha that was awesome
[quote]If you don’t have a domestic they look at you like your dropping someone off at the track.
Ubly and Lapeer you can basically hot lap at…No real lines. If by more laid back you mean in the middle of a field with whoops at mid track then yes Lapeer is the most laid back track in the world. Are guys from the area or do you have a bit of travel?
what are whoops?
The bumps on the Motorcross track.
lol
lapeer is kind of redneck… http://www.youtube.com/watch?v=kjg5cHNUc8s&feature=plcp
What the fuck was that truck doing? I mean besides being faster than 8urv8’s car…
Literally “laying rubber” on the track, lmao, dragging the fucking tire behind it.
sakimano:
it looks like he is dragging an old truck tire around?
Lol yeah lapeer is ghetto as fuck
Now Hunter knows why I warned him yesterday that I couldn’t add lapeer times to our dragstrip time database
P.S. Meow you are new…you should check it out. Let me know if you have any times I can add for your car (Milan or ugly)
[quote=“sakimano,post:33,topic:3746”]
Looking for this database, where that be at yo? lol
I have some times from Lapeer today (crappy, but whatever) and some times from 131 over near Kalamazoo.
Are you in the michigan area?
[quote=“Meow,post:34,topic:3746”]
Audirevolution.net/quartermile
You can search, sort, whatever you like.
No I am in Canada, but visited Detroit two weeks ago and met these guys there.
ChrisK:
lmfao
What did you run and what is your set up?
[quote=“SHOStprS4,post:37,topic:3746”]
sakimano:
RS6 OEM BW turbos
Valves, springs, retainers, whatever: Supertech spring kit
Headgasket: RS4
Diverter Valves: 710n’s
Tune : Vast Custom
MAF (brand and size): Vast 90mm Aluminum Elbow (4") with integrated MAF housing
Injectors: Bosch EV14 Injectors
Fuel Pump: Deatschwerks 300lph
Fuel Pressure Regulator: Vast 5 bar
Air Intake/Filter: AEM Dry Flow Open Element Filter (4")
Clutch: Vast Kevlar with modified RS4 Pressure Plate
Flywheel: Single Mass
Intercooler(s): AWE Side mounts
Mounts (motor, tranny and snub): apikol snub mount, stern tranny mounts
Exhaust: SSAC full exhaust
Downpipes: SSAC modified to fit OEM RS6 turbos
Wideband: Zeitronix ZT-2 with LCD display of AFR, Boost and Oil pressure
Miscellaneous: Vast Electric fan kit, Vast Phenolic spacer, JHM short shifter, Rebuilt trans with upgraded syncros and 1-2 shift collar and taller 6th gear.
-Performance-
(very very conservative tune)
Boost spike:23
Boost at redline:22
Fats time:3.6
1/4 Mile E/T: 12.6
1/4 Mile MPH: 115
1/4 Details: bad launch and shifting, im a crappy driver, lol. 115 mph has a lot more ET left in it…
https://sphotos-b.xx.fbcdn.net/hphotos-prn1/533891_10151368854607664_2037033130_n.jpg
RS6s? I that’s crazy they are open this late in the year. What do you think of your taller 6th gear?
Yes RS6’s, I LOVE the taller 6th gear, dropped the revs about 800rpm on the highway, I get about 30mpg if I only drive on the highway.
