Front motion ratio is 0.65
rear actually has a motion ratio like a mac strut. Look at where the spring is located - it’s attached to the knuckle.
The 0.65 number came from reverse calculating Stasis provided #'s, but Stasis messed up on their calculations
If you look at the design of the rear suspension, you’ll see why it’s nearly 1:1
pic for reference
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/wUsAAOSwo8hTnzov/$_1.JPG
See the rear spring holder? It’s the same part as the knuckle (which holds the wheel bearing). So the wheel is acting with direct force on the spring. It’s on the same pivot point. another pic below for clarity:
At best, the rear motion ratio is between 0.85 to 0.95. Regardless, it’s very close to 1:1 and shows why spring rates for coilovers on this car have such a front bias. But if you factor in the motion ratios, the wheel rates end up being as you’d expect them to be.
For example, the R8 rear suspension, although a different design, has a hard mounting point also right on the knuckle. The motion ratio of that car has been calculated to be 0.875:1. So anyway, it’s safe to say our car is in the 0.9 range. I use 0.9 to calculate my wheel rates for this car
