Someone has told me, that the notorious chain “rattle” on the v8 FSI is a total misnomer. Apparently chain problems in that case sound like someone is banging a hammer on the block.
I’m guessing the ticking is coming from the cam adjusters and noisy injectors doing their…  doings as normal, might be slightly louder for a moment at startup and cold starts.
I have an exhaust leak, and for the first 60sec my s6 sounds like a Harley, because the SAI pump is pushing extra air into the exhaust to warm up the cats. So that is one thing to take into account. It also makes for a rough idle, so it’s good to wait a few minutes, before driving off.
Also, the engine is designed to run 5w-30. So anything thicker, will probably make it more noisy, that thick tar won’t flow as freely in the tiny passages they designed for 5w-30 oil.
