Attempt to revive this thread, see what people are rocking these days, as most links here are dead by now. Anyone running 275/30 on 20-10 ?
I ran 265/30 on 20" in the rear with no problem, I now rock 285/30 20" in the rear and it rubs a little on the fender lining both on 10" wide rims with ET35.
But it seems like it can be fixed.
I am lookin at some JR28 10" ET40, and scared it will rub 275/30s, and some R series R9 10" ET50 which i reckon should fit nicely. Since you say in the rear specificly, are u running staggered? Or did u use same in front, without rubbing on both widths?
Yes, I run staggered, so 245/35 20" 8.5" wide with ET32 in the front.
willtheyfit.com is a great place to look and compare.
What you are looking at vs. what I have.
I have 275/30 r 20x10 on my car, lowered with HnR springs
You recall the ET? And no rubbing:)? This is like, exactly what I am looking at so:)
Nice, the 20s certainly suit the car, I believe the et is 35 all round.
The previous owner put these on and I can’t imagine the car with smaller wheels
I have 15mm spacers on the rear and none on the front
The only rubbing I have is when the suspension is compressed but that is likely due to the lowered set up
I plan on raising the car to address this but other than that no rubbing anyhere else
