[quote=“justincredible,post:16,topic:7473”]
So I ended up pulling the codes from ABS as well as the engine this afternoon.
http://i.imgur.com/EBRGtk0.jpg
That wheel speed sensor was replaced about a week or two ago so I know it’s not the actual sensor.
The G85 sensor error is new, never seen it around before.
Both faults are intermittent which makes sense because the issue itself it intermittent.
Here are the engine fault codes.
http://i.imgur.com/8xgwnml.jpg
Engine mount codes started showing up about a month ago. Replacing the mounts and resistors here in a bit so that should take care of that.
I have a JHM Tune and I would think the tune would suppress those O2 sensor codes but I guess it isn’t? Curious, Might have to buy some spark plug defoulers to fix that.
The other two seem to be identical faults to the ones that showed up in the ABS scan
After all that, I did an output test with the ABS and nothing really came up but because the ignition was left on for that long, this code showed up in the fault code scan again after I had cleared it 5 minutes prior and not even started the car or anything.
