Stop. Please repeat after me:
The compressor map does not say diddly squat about the total efficiency of the supercharger or turbocharger. Do you see parasitic loss on that map? Do you see the turbine efficiency of the turbo? No you don’t.
I only posted it to illustrate that there is nothing inherently different in compressor maps. I compared entirely different compressor wheels. And the turbo isn’t variable at all, whatever you mean by that
[quote]Look how more more boost is obtained at 1/2 the pressure ratio.
Pressure ratio IS boost. What the hell are you on about? At every corner of this argument you demonstrate that you don’t have an actual clue of the subject matter. But keep downvoting my karma each time you get your nose rubbed in your own ignorance, why not.
[quote]Not only that but the turbo JC posted iis huge and would have incredibly terrible lag. If we are cheery picking compressor maps this one just dominates the argument and you can close up shop…
Serious question: do you think you could actually fit that supercharger to an RS4 to name one car? The garrett turbo I happened to link to (i just took something with similar flow rates to get the scale right anyway) is not inherently laggy, it always depends on the size of the engine you’re strapping it to.
[quote]you can run 78% from just under 300 CFM to over 1200 CFM all at less then 2 pressure ratio.
Yes, you can. How big does an engine need to be for the supercharger to do this, however?
Try and calculate how big an engine needs to be (let’s assume 100 percent VE) to consume 1200 CFM at 2.0 PR at maybe 7000 rpm? And keep in mind the surge line on the left.
[quote]JC is consistently wrong so he argues semantics.
The difference between volumetric efficiency and isentropic efficiency is semantics? ??? They’re completely different things! You’re the one who started arguing compressor maps and then proceeded to display his complete ignorance of them.
[quote]A supercharger looses less air
What?
[quote]and has larger islands for its efficiency.
No. And again you seem to think a compressor map is relevant to the whole of the supercharger.
[quote]The VE for the air
What? Zero meaning detected.
[quote]adiabatic…is part of the map but it’s the over all map it’s range and adiabatic efficiency and the other factors that lead you to the VE.
No, it doesn’t. In no way, shape or form is VOLUMETRIC efficiency related to the THERMAL efficiency of the compression process. No way. If you have an old physics schoolbook lying around somewhere please open it. You are talking absolute jibberish here.
[quote]As the volume of air can carry a larger CFM before heat rise becomes an issue.
You’re saying the same volume of air can carry more volume here.
Congrats.
You’ve now established that a supercharger not only has more boost at the same boost but also that it has more volume for the same volume. You might be up for a Nobel prize this year if you’re not careful.
[quote]If turbos were better you wouldn’t need two of them to do the work of one supercharger.
I’m starting to think I’m on Candid Camera. Tell me the truth is this a wind-up?
[quote]Lag and pressure raise increase turbo Temps past those of supercharged apps.
Mmmno. And how do you imagine lag affects temperatures anyway?
[quote]It’s not hard to see that a supercharger can make more CFM at a lower pressure ratio with better efficiency.
Sigh. No. Any difference that exists in compressor maps is purely the result of differently designed compressor wheels because of various reasons such as the shaft speeds of a supercharger typically being slower than turbos.
How often do I need to tell you that you are looking in the wrong place to find the difference between turbos and superchargers? The compressor maps DO NOT APPLY TO THE ENTIRE TURBO OR SUPERCHARGER.
