this^^^
battery re-locate seems like a pipe dream for performance but it never seems to work.
You’re moving a 35lb (if you’re moderately light with the optima) to the rear of the car…which in itself is not really a notable amount of weight to shift (1% of the car). The car is 15 feet long, and the battery is already ‘mid-mounted’ between the axles. It’s about 4 feet from the front nose. Putting it into the trunk at say 12 feet from the front nose means you’re shifting 1% of the car’s weight back about 8 feet. Not a huge change there.
Further, adding ~10 feet of the heavy gauge, quality wire you need to move it there, and then building a proper bracket and sealing it off to meet safety standards is going to eat into a good portion of your ‘weight loss’ by going LW battery
Finally you’re looking at a new fire hazzard that should see you punted out of just about any racetrack worth their salt on technical inspection.
All in all, it’s a questionable use of your mental, physical and financial resources.
