I have tried searching the web but not having much luck. Do I need to replace and re-component protection a new J520?
Car works fine, but occasionally / randomly throws the EPC and CEL + instrument cluster goes dark, lift gate wont open, etc…
My gut tells me it may just be a bad battery, it is starting weakly and symptoms seem to go away if battery is on a charger…
Full Scan:
VIN: WA1DGAFE7ED017233 License Plate:
Mileage: 244260km-151776mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE7ED017233 Mileage: 244260km-151776miles
04-Steering Angle – Status: OK 0000
10-Park/Steer Assist – Status: OK 0000
15-Airbags – Status: OK 0000
28-HVAC, Rear – Status: OK 0000
34-Level Control – Status: OK 0000
3C-Lane Change – Status: OK 0000
4C-Tire Pressure II – Status: OK 0000
55-Headlight Range – Status: Malfunction 0010
56-Radio – Status: OK 0000
5F-Information Electr. – Status: Malfunction 0010
69-Trailer – Status: Malfunction 0010
6D-Trunk Elect. – Status: Malfunction 0010
6F-Centr. Conv. II – Status: OK 0000
VCDS
Self-Diagnosis Log
Saturday,06,July,2024,08:03:57:27841
Page 2
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08— Serial number:
Coding: 0121000A290F0928
Shop #: WSC 13622 410 403014
VCID: B620BDDDC12B3C2629-80E2
VINID: 9D10545D15951D55000470830CEA7C37F4
4 Faults Found:
001170 - Secondary Air Injection System: Bank 2
P0492 - 000 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 4
Reset counter: 255
Mileage: 241624 km
Time Indication: 0
Date: 2023.12.04
Time: 10:37:54
Freeze Frame:
RPM: 896 /min
Mass Air / Rev.: 212.6 mg/str
Temperature: 34.5°C
Bin. Bits: 00000010
Voltage: 13.06 V
Bin. Bits: 00000010
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 6
Reset counter: 255
Mileage: 243762 km
Time Indication: 0
Date: 2024.05.18
Time: 08:38:30
Freeze Frame:
RPM: 1216 /min
Mass Air / Rev.: 169.0 mg/str
Temperature: 31.5°C
Bin. Bits: 00000010
Load: 16.5 %
Speed: 0.0 km/h
000771 - Cylinder 3
VCDS
Self-Diagnosis Log
Page 3
Freeze Frame:
Fault Status: 11100010
Fault Priority: 6
Fault Frequency: 5
Reset counter: 255
Mileage: 244119 km
Time Indication: 0
Date: 2024.06.18
Time: 09:45:05
Freeze Frame:
RPM: 1280 /min
Mass Air / Rev.: 267.1 mg/str
Temperature: 31.5°C
Bin. Bits: 00000010
Time: 0.0 s
Speed: 0.0 km/h
004874 - Cylinder Disabling
P130A - 000 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 244119 km
Time Indication: 0
Date: 2024.06.18
Time: 09:45:05
Freeze Frame:
RPM: 1216 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 31.5°C
Bin. Bits: 00000010
Time: 0.0 s
Speed: 0.0 km/h
Readiness: 0000 0000
VCDS
Self-Diagnosis Log
Page 4
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number: CVN: C6617F96
Coding: 001378
Shop #: WSC 99999 999 83333
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_AU56.rod
VCID: BA38A9ED3D33D846CD-80EE
No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0103505
Shop #: WSC 31414 790 00001
VCID: B42487D5D7572E3617-80E0
No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702121796
Coding: 0000135
Shop #: WSC 10450 005 1048576
VCID: A5026A916C8D47BE90-80F0
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
VCDS
Self-Diagnosis Log
Page 5
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00—031 Serial number: 00000000417615
Coding: 180CC026
VCID: A5026A91AC8D47BE90-80F0
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0090977992
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0090978073
Coding: 070000
No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0133121
Shop #: WSC 23559 002 104857
VCID: EE9055BDF9FB44E621-80BA
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 23559
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 23559
VCDS
Self-Diagnosis Log
Page 6
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961405000154
Coding: 25011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: B42487D51F572E3617-80E0
No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD900PB9
Coding: 0014131
VCID: AB169CA90A6971CE46-80FE
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME1D3F367E.
Subsystem 3 - Serial number: 6342QSME163F4744K
Subsystem 4 - Serial number: 6352QSME503C396ET
Subsystem 5 - Serial number: 6362QSME1D3F3646T
Subsystem 6 - Serial number: 63734SME2F3E3854C
Subsystem 7 - Serial number: 63834SME123D4040T
VCDS
Self-Diagnosis Log
Page 7
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026140550173
Coding: 0012142
VCID: A81C63A51B9F5AD6AB-80FC
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4L0-920-KOM-V3.clb
Part No SW: 4L0 920 985 S HW: 4L0 920 985 S
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2R00LU2F
Coding: 83FF63040901C705020205
VCID: C4C4D71547F79EB6A7-8090
No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M1420901D8
Coding: 00C303
VCID: BFCED8F92E11FD6EFA-80EA
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 31043N11004121790585
No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00—011 Serial number: 00000000418437
Coding: 0000006
VCID: E89C23A5DB1F9AD66B-80BC
VCDS
Self-Diagnosis Log
Page 8
Address 34: Level Control Labels: 4L0-910-553.clb
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
VCID: B12A8EC128451B1E7C-80E4
No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000091330885
Coding: 00581B00000011110000
VCID: B22881CDED43200605-80E6
No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: AE1095BD397B04E661-80FA
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H02 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F14.02.1400H02000AMS16362ÿ
Subsystem 4 - Serial number: S16362ÿ
VCDS
Self-Diagnosis Log
Page 9
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000092625583
Coding: 011F57205E40440004
VCID: C8DCC3257BDFBAD64B-809C
No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 — Serial number: 01942799710000
Coding: 3570173
VCID: B83CB3E5CB3FCA563B-80EC
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Component: IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 2
Mileage: 163835 km
Time Indication: 0
Date: 2019.12.14
Time: 22:33:30
02103 - Control Module 2 for Vehicle Electrical System (J520)
** 013 - Check DTC Memory**
** Freeze Frame:**
** Fault Status: 01101101**
** Fault Priority: 3**
** Fault Frequency: 254**
** Reset counter: 2**
** Mileage: 163835 km**
** Time Indication: 0**
** Date: 2019.12.14**
** Time: 22:48:32**
VCDS
Self-Diagnosis Log
Page 10
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000033592
Coding: 030000
VCID: A91A66A1C09563DEB4-80FC
No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191044252
Coding: 0694221
VCID: A306748962B9B98EFE-80F6
No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000174649
Coding: 0012001
VCID: DEF0057D095BD46691-808A
No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000092635242
VCID: C7DEC01976C1B5AE42-8092
VCDS
Self-Diagnosis Log
Page 11
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 2
Mileage: 244264 km
Time Indication: 0
Date: 2024.07.06
Time: 07:55:57
------------------------------------------------------------------------------- Address 56: Radio ® Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156B10E7970647
Coding: 020007010000000000
VCID: A4047795A7B7BEB687-80F0
VCDS
Self-Diagnosis Log
Page 12
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 746 E HW: 4L2 035 746 D
Component: H-BNT-NA H41 0756
Revision: -------- Serial number: 224BO0E7540233
Coding: 180200060104F3FF5B00AF4D6D732003140000000300000000
VCID: B02C8BC5E34F121673-80E4
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130BY0E2952479
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002168357
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 3
Reset counter: 2
Mileage: 244264 km
Time Indication: 0
Date: 2024.07.06
Time: 07:56:10
Freeze Frame:
Bin. Bits: 00000000 00001000
Bin. Bits: 00000010 00000100
Bin. Bits: 00000000 00000000
VCDS
Self-Diagnosis Log
Page 13
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000092660909
Coding: 010E57204040230004
VCID: C6C0CD1D71CBACA6B9-8092
No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000325927610
Coding: 0200000000000000
VCID: B12A8EC1E8451B1E7C-80E4
1 Fault Found:
00532 - Supply Voltage B+
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 224678 km
Time Indication: 0
Date: 2022.09.24
Time: 19:39:47
------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H09— Serial number: 525PA8-J4240HE
Coding: 1021001
VCDS
Self-Diagnosis Log
Page 14
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: EC945FB5CFE7B6F60F-80B8
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: & ó
Subsystem 3 - Serial number: RD22.02.14–H58001002E0327ÿ
Subsystem 4 - Serial number: 2E0327ÿ
1 Fault Found:
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 243762 km
Time Indication: 0
Date: 2024.05.18
Time: 08:32:58
------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0092767365----
Coding: 0003595
VCID: A6006D9D118B4CA699-80F2
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H14 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H14 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H14 0220
VCDS
Self-Diagnosis Log
Saturday,06,July,2024,08:03:58:27841
Page 15
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000092648541
End----------(Elapsed Time: 02:34, VBatt start/end: 12.8V/12.9V)-----------
