Weird that the numbers are so different. Dynomite(L&S) and Mustang dynos are almost the same thing, with the Dynomite essentially being a more precise, high end version with more applied variables. Both are eddy current type.
Unless there was something wrong with it, their old dyno was more accurate assuming it was set up properly.
So, EBwerks 2.75" catless downpipes and 2.75" catback exhaust vs stock diameter AWE catback…and the ebwerks fullback added a loss of 2 WHP??
Funny, Ben hasn’t addressed that little discrepancy lol.
[quote=meem on quattroworld]speaking of videos – and proof that i will get my rs4 dirty for a good cause: i had it baselined on 034’s mustang dyno this wet morning.
it fared better than i expected (327 whp) and we probably should’ve let it adapt more, as it got stronger with each of the three runs (just apr chip and awe exhaust).
as a datapoint, an rs4 with jhm’s supercharger recorded 390whp on that dyno last month.
it will be interesting to see the tvs1740 supercharger numbers soon
The other tidbit that keeps popping up is that a JHM supercharger kit dyno’d at “only 390whp” but what no one seems to understand is that a.) it is a stage 1 kit and b.) the whole point of stage 1 is to get ready for stage 2. So, yeah sure it will be interesting to see the APR kit’s numbers on that dyno but even more so the JHM stage 2 kit’s numbers. Then we will be comparing apples to apples and still at a substantial cost and more importantly in mind boost difference.
I’d say that’s reasonable. Run to run will have variances, especially if we’re talking in the neighborhood of only 2 AWHP and only two data points, that being the peak power figure and not an entire dyno curve. On these big V8 engines, even differences in oil temp will play into a few HP here and there. Id look at the whole curve. It will be far more beneficial.
We tend to see a full catless exhaust produce pretty significant peak delta over one with stock downpipes and just a catback.
Arin, any thoughts on why BenST-Lie’s car dyno’d 3 WHP less when they added the APR tune? 034 said ‘it needs to adapt’ but I thought I remembered you saying on here somewhere that adaptation talk is a bit over-rated and the cars adapt right away. Maybe that was on the B8 not the B7.
stock everything 327 whp
add jhm tune/full exhaust 365 whp
same fuel, same conditions
+38 peak whp
I guesss you’re saying that gain of peak whp is just from the JHM tune? And if we were to take the JHM exhaust off his car, and put the stock exhaust with all cats in the downpipes back on, he would lose a little of the fatness in the curve, but make the same peak WHP?
