So I dont know if something hokey is going on, but…something hokey is going on.
FIrst off, when I got the car, someone tinkered with the wiring under the right (passenger) e box.
This a BVJ engine mind you.
oam wiring diagram calls for a J271 relay which is the ECM power supply…I only have a 373 under there, and I see a red/green wire has been cut with a purple wire splitting off into 2 643 relays, and then 2 mroe small purpel wires branching into 1 OEM looking gold connector to the power distribution block… These 643 relays dont exist on any wiring diagram…
so when the fans come on…both turn off when I pull one of these 643 relays off…
However what is most concerning, is as I was pulling these two relays in and out, i later went to go start the car…and now the PRNDL is all lit up, and the ECM is not communicating at all…continuity tested all fuses, all good…
did one of the 643 relays just stick open on me? Going to test both relays tomorrow on the bench and see… need to pull some more relays from the junkyard.
I have a c6 s6 here, and i checked under the right box…those relays dont exist, no hokey cut and spliced wiring…jhust the one relay at the bottom (dont remebr if it was 271 or 373)…
So frig, now I gotta see if the ECM is even getting power. If its not…then trace it back to where it should be…
if it IS getting power…then im facked.
Looks liek connector 94, pin 92 and 69?
https://i.imgur.com/UXYvDty.jpg
https://i.imgur.com/UhAJuVl.jpg
