I have not been taking many pictures lately as I have just been cleaning and re-assembling the original components that were removed six months ago. With all the hoses and wiring on these engines, I have spent a fair bit of time going over the pictures I took last October to make sure things are going back on in the reverse order that I took them off. Logically, you just work from the bottom of the engine up. (ie. a/c compressor, power steering pump, starter, engine mounts, manifolds, coolant pipes)
Here is the power steering pump and associated fasteners
http://audirevolution.net/addons/albums/images/428384036.jpg
The only thing I replaced as far as the power steering pump was concerned were the two metal gaskets that seal the banjo bolt connection to the pressure line. I removed the pressure line so I could confirm that the pump was full of fluid (before reinstalling) by pouring oil into the suction line and manually turning the pump until oil came out the discharge side. The splines on the drive shaft were coated with spline grease and the pump was re-installed.
Here is a shot of the starter installed with the after run coolant pump. The electrical connection to the starter and alternator was also installed at this time as it is much easier to do before the exhaust manifolds are put on.
http://audirevolution.net/addons/albums/images/801038526.jpg
Here is a shot of the coils and plugs.
http://audirevolution.net/addons/albums/images/982008148.jpg
I went with a one step colder plug to go along with the JHM tune/exhaust and my plans to drive it hard once I get it back on the road. If I get any fowling, I still have my stock NGKs, which are less than two years old, that I can through back in. The coils were all replaced less than two years ago so I did not see a need to replace them.
Here is a shot of the manifold gaskets along with the copper plated nuts and the Audi āhot boltā paste which looks like some form of copper based anti-seize.
http://audirevolution.net/addons/albums/images/142838811.jpg
When I was removing the exhaust tracts last October, half a dozen of the studs came out the heads as the nuts were seized in place. The studs in the heads are available as a separate part.
http://audirevolution.net/addons/albums/images/219099795.jpg
Unfortunately , the studs in the ends of the exhaust tracts are not. When I replaced one of my y-pipes last summer, two of the nuts were so seized, they just rounded right off when I put the socket to them. I ended up cutting half the nut off with a die grinder and then knocking the rest off with an air chisel. In the process, I gouged out a few chunks with the die grinder so I replaced the three studs with pieces of stainless steel threaded rod.
http://audirevolution.net/addons/albums/images/483657221.jpg
Prior to installation, a thread chaser was run through all eight O2 sensor ports and a die was run across all of the studs
Here is a current shot of the engine with the manifold tracts installed.
http://audirevolution.net/addons/albums/images/775116584.jpg
With the exhaust installed, it is time to move onto the cooling system.
I believe I counted twenty six different coolant hoses in the engine compartment.
Here are the parts diagrams for the FEED and RETURN sections of our cooling systems.
http://audirevolution.net/addons/albums/images/11875652.jpg
Some of them are ridiculously expensive so I decided to only replace the ones that either needed to be replaced or were completely in accessible (or require a fair amount of disassembly work) with the engine in the vehicle.
I will leave it at that for now as I am currently waiting on some of the hoses I ordered to arrive.
