I donât recall there being anything totally unexpected or especially noteworthy during the project.
If you have patience, perseverance, the tools and the FSM, you just take your time and work through it methodically.
Unless you have severely overheated your engine to the extent that I did, there should be no need to tear things down to the bare block. If you do need to do this, then:
Organization is key â group, bag and label all your smaller parts during disassembly
Take lots of pictures during disassembly â especially the electrical and plumbing
Use an online Audi parts database to identify all the seals and bolts, etc. that you need as you work through the disassembly process â This should save you some time and frustration at the dealership. I would just email my parts lists to the local dealer and then pick them up the next morning.
It is an Android touchscreen communicating wirelessly with the HEX NET interface in AP mode.
I originally installed the touchscreen last year so I could run a more modern navigation app. It was only after I installed it that I realized I could just install VCDS mobile and not have to use my phone or laptop.
The MMI interface is still there. An FM transmitter broadcasts it to the touchscreen. It automatically switches to the back-up camera image when you shift into reverse.
