07 - S6 Coolant in oil - Complete Engine Teardown
Originally I was going to wait until this project was complete (and confirmed successful) before creating this thread, but then I figured it would not give as much of an opportunity for people to comment or ask questions along the way.
I have had my 07 S6 for about three years now and have thoroughly enjoyed driving it for most of that time. Currently there is about 250,000 km (155,000 miles) on the vehicle.
I had my share of the typical v10 issues (oil leaks, intake flap failures, broken electrical connectors and injector related misfires) and addressed them all accordingly. As far as mods go, I have the JHM: tune, catback exhaust, intake spacers and LW crank pulley.
I installed a lift in my garage this past summer with the intent of dropping the drivetrain next spring for the purpose of installing headers and resolving the oil leaks that cannot be addressed with the engine in the vehicle.
It was then decided that the engine drop plan needed to be fast tracked when I discovered what looked like “chocolate milkshake” residue under my oil filler cap one day a couple of months ago. The results of a sample sent to Blackstone confirmed my suspicion that there was coolant getting into the oil.
Once the oil results came back, I performed compression and leak down testing to give me an idea of the general health of the engine and if there was evidence of a head gasket failure.
Below is a summary of the numbers I obtained. The compression was quite reasonable across all cylinders. The numbers were still climbing when I stopped cranking but I wanted to limit it to six compression cycles on each cylinder for consistency. The leakdown numbers were ok with a couple of cylinders posting notably higher leakage rates than the others. At no point did I hear air coming out the intake, exhaust or adjacent cylinders so I was confident at this point that the leakage was mainly blowby past the rings into the crankcase. I will redo the leakdown test before I re-install the engine back in the car.
http://audirevolution.net/addons/albums/images/784397960.jpg
Other than the headgasket, the only other potential oil/coolant mixing points I could think of were the oil cooler and the internal coolant pipes that run from the cam timing covers into the ends of the cylinder heads.
At this point, I figured I would just pull the cam timing covers off and change the o-rings; then pull and pressure test the oil cooler and replace if necessary.
I am doing this work in a two car residential garage. It was obvious that with all of the tool and storage cabinets already in there, I would not have enough room to do any work on the dropped engine with the car in there as well. I needed a way of rolling the dropped engine/tranny combo out from under the car and then a method of rolling the car out of the garage without the subframe attached.
I ended up modifying a motorcycle lift by adding a sheet of plywood to stiffen up the deck and a set of four 6”casters that would contact the ground once the lift was fully lowered.
Here is a shot of the lift before the casters were added. It will make a good variable height work platform for the garage when this project is done. I would sell it but I very much doubt that this will be the last engine drop I ever do.
http://audirevolution.net/addons/albums/images/314978929.jpg
The mechanical part of the drop was very straightforward. I went pretty well by what is presented in the Bentley manual. I found removing all the electrical from under the cowling more cumbersome as you have to be very careful not to pull too hard on any of the wires as some of the connectors are getting quite fragile in their old age. When you are lowering the engine (or raising the car), the ecus and all of the other electrical has to be piled on top of the engine. In my case, I really had to watch the height as I can only lift the car so high in my garage and I still had to be able to roll the lowered drivetrain out from under it. It cleared by about 2”.
Here is a shot of the dropped engine being rolled out from under the car. You will notice that I have a winch line on it to keep it from getting away on me due to the slope in the floor of my garage.
http://audirevolution.net/addons/albums/images/695904436.jpg
To get the car out of the garage, I lowered the front end onto a dolly I made and pushed it out using a winch to stop it from getting away on me due to the slope of the driveway. I will also need it to pull the vehicle back in for the re-install.
Here is a shot of the dropped powertrain on the lift. You can see the front end of the car on the dolly in the background.
http://audirevolution.net/addons/albums/images/233996758.jpg
Another one taken from the rear. One of the many pics that I took during the disassembly process.
http://audirevolution.net/addons/albums/images/251061558.jpg
You will note that the rear cam covers have been removed and it is not real pretty inside
Here is a closeup:
http://audirevolution.net/addons/albums/images/935322962.jpg
This stuff is like tar. It does not come off easily with a simple wipe of a rag.
I am pretty sure this is the result of a major overheating (due to loss of coolant) incident that I had a couple of years ago. The engine got so hot that the red oil light actually came on. I had already been driving for about a half hour with the engine coolant temperature gauge pinned but it was a situation where I could not stop the car so I drove for another couple of minutes (with the oil light on) till I got to my destination and then shut it off. I thought for sure the engine was done. It was not a good situation as I was 200 miles from home in an underground parking garage with no tools. I went out the next morning to see if I could find the source of the coolant leak. I could not see anything given the limited visibility we have of the hoses under the hood. The oil level on the dipstick was good although it was a little on the dark side. I had to get the car out of the underground parking so it could be loaded onto a flatbed for the long drive home. I was quite relieved when only the coolant level warning came on and not the one for the oil when I started the engine. After getting it home, I found that the short right angled coolant hose that connects to the alternator had failed. Its premature failure was likely the result of me being a little too rough with it when I changed out my oil cooler o-rings about 4 weeks earlier
Here are a couple more pics showing the extent of the overheated oil situation
Under valve covers:
http://audirevolution.net/addons/albums/images/985950915.jpg
Oil pickup tube and pump inside upper oil pan:
http://audirevolution.net/addons/albums/images/913034827.jpg
After seeing all the “cooked” oil, I decided I was going to have to take it right down to the bare block to inspect and clean everything.
At this point, I am going to fast forward to the stage I am at right now as I am sure pictures of dirty parts in a partially disassembled engine are not going to be of interest to a lot of you.
I have the cylinder block separated from the crank guide plate with the crank removed right now.
http://audirevolution.net/addons/albums/images/57985435.jpg
I wanted to see the condition of the connecting rod and crank journals and bearings given the low oil pressure light that came on when I overheated the engine.
Here is a shot of the crank guide frame (engine bed plate) with the lower bearing shells still installed
http://audirevolution.net/addons/albums/images/920367062.jpg
As you can see, there is a fair amount of scoring in the bearing for journal number five and some to a lesser extent in the other five bearings. The crankshaft journals all look fine.
I did not take any pictures of the rod bearings. There was no scoring on them; just scuffing similar to what you see on the bearing for journal #1 above.
I have replacement upper and lower bearing shells for both the crank and rods on order along with all of the bolts. I will be verifying that the radial clearance for all of the bearings is within spec before torquing everything down.
That is it for disassembly.
The next step is always my favorite … cleaning. (stay tuned)
