07 S6 - VERY rough cold start. BAD Misfires at idle and under load
Hey guys, I’ve yet to post here but hope the V10 experts can help.
Bought the car a couple months ago out of state. CEL popped on an hour into my drive home. Slight misfires felt at idle. Idle slowly got more rough as the temps dropped here in Vermont. Cold start got worse each week to the point it would almost take 3 seconds to fire up then run rough (VERY) with a flashing CEL until things somewhat smoothed out (still misfiring).
Had a friend do a carbon cleaning at his shop. Definitely had a carbon issue. Replaced a very bad leak at the oil cooler which was spilling oil past the gasket, so that at least was fixed. Now the idle issue is worse. Before the cleaning I had a rough idle, but I could go WOT in gear without a flashing CEL, now I get stutters at nearly any throttle and get a flashing CEL if I go 3/4" lower RPM in 3rd gear. If I turn the car off after it’s fully warmed up and start it again, it’s a bit better.
Carbon is gone, plugs have been replaced, have only replaced one coil after codes were seen for cyl 5. I suspect the injectors are leaking/bad? From searching various forums I haven’t found a be all solution, but most successful threads ended with all injectors being replaced.
I also have a too lean at and off idle code, perhaps also related to the injector issue. I’ve been told it is most likely a vac leak near the intake, but so far haven’t found anything.
Your input is greatly appreciated!
Just scanned after two weeks driving after the carbon cleaning. This is Engine, Engine II and Engine other:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4F1 910 552 A HW: 4F1 907 552
Component and/or Version: 5.2L V10/4V FSI ª0040
Software Coding: 01050009190F0160
Work Shop Code: WSC 02335 785 00200
VCID: 2241E5D7FDDA0D2E6B-8076
3 Faults Found:
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154260 km
Time Indication: 0
Date: 2015.11.19
Time: 13:50:32
Freeze Frame:
RPM: 656 /min
Load: 12.9 %
Speed: 0.0 km/h
Temperature: 97.0°C
Temperature: 15.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
008585 - Bank 2; System too Lean at Idle
P2189 - 004 - - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154260 km
Time Indication: 0
Date: 2015.11.19
Time: 13:50:33
Freeze Frame:
RPM: 642 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 97.0°C
Temperature: 15.0°C
Voltage: 14.097 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154753 km
Time Indication: 0
Date: 2015.11.25
Time: 15:05:23
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Temperature: 54.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.176 V
7 Faults Found:
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154175 km
Time Indication: 0
Date: 2015.11.17
Time: 19:46:58
Freeze Frame:
RPM: 3474 /min
Load: 96.0 %
Speed: 86.0 km/h
Temperature: 93.0°C
Temperature: 9.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.462 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154175 km
Time Indication: 0
Date: 2015.11.17
Time: 19:46:58
Freeze Frame:
RPM: 3474 /min
Load: 96.0 %
Speed: 86.0 km/h
Temperature: 93.0°C
Temperature: 9.0°C
Voltage: 13.462 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154188 km
Time Indication: 0
Date: 2015.11.18
Time: 18:55:41
Freeze Frame:
RPM: 1591 /min
Load: 41.6 %
Speed: 32.0 km/h
Temperature: 41.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154194 km
Time Indication: 0
Date: 2015.11.18
Time: 20:11:41
Freeze Frame:
RPM: 749 /min
Load: 25.5 %
Speed: 15.0 km/h
Temperature: 57.0°C
Temperature: 23.0°C
Voltage: 13.970 V
000777 - Cylinder 9
P0309 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154194 km
Time Indication: 0
Date: 2015.11.18
Time: 20:11:41
Freeze Frame:
RPM: 749 /min
Load: 25.5 %
Speed: 15.0 km/h
Temperature: 57.0°C
Temperature: 23.0°C
Voltage: 13.970 V
000784 - Cylinder 10
P0310 - 008 - Misfire Detected - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154194 km
Time Indication: 0
Date: 2015.11.18
Time: 20:33:32
Freeze Frame:
RPM: 679 /min
Load: 28.2 %
Speed: 8.0 km/h
Temperature: 57.0°C
Temperature: 30.0°C
Voltage: 13.716 V
000775 - Cylinder 7
P0307 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154235 km
Time Indication: 0
Date: 2015.11.19
Time: 13:10:46
Freeze Frame:
RPM: 738 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 50.0°C
Temperature: 18.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.224 V
Address 31: Engine other Labels: Redir Fail!
Additional Info: 4F1910552A 5.2L V10/4V FSI ª0040
Address 01: 3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154260 km
Time Indication: 0
Date: 2015.11.19
Time: 13:50:32
Freeze Frame:
RPM: 656 /min
Load: 12.9 %
Speed: 0.0 km/h
Temperature: 97.0°C
Temperature: 15.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154260 km
Time Indication: 0
Date: 2015.11.19
Time: 13:50:33
Freeze Frame:
RPM: 642 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 97.0°C
Temperature: 15.0°C
Voltage: 14.097 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154753 km
Time Indication: 0
Date: 2015.11.25
Time: 15:05:23
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Temperature: 54.0°C
Voltage: 11.176 V
Address 11: 7 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154175 km
Time Indication: 0
Date: 2015.11.17
Time: 19:46:58
Freeze Frame:
RPM: 3474 /min
Load: 96.0 %
Speed: 86.0 km/h
Temperature: 93.0°C
Temperature: 9.0°C
Voltage: 13.462 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154175 km
Time Indication: 0
Date: 2015.11.17
Time: 19:46:58
Freeze Frame:
RPM: 3474 /min
Load: 96.0 %
Speed: 86.0 km/h
Temperature: 93.0°C
Temperature: 9.0°C
Voltage: 13.462 V
000776 - Cylinder 8
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154188 km
Time Indication: 0
Date: 2015.11.18
Time: 18:55:41
Freeze Frame:
RPM: 1591 /min
Load: 41.6 %
Speed: 32.0 km/h
Temperature: 41.0°C
Temperature: 24.0°C
Voltage: 14.224 V
000774 - Cylinder 6
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154194 km
Time Indication: 0
Date: 2015.11.18
Time: 20:11:41
Freeze Frame:
RPM: 749 /min
Load: 25.5 %
Speed: 15.0 km/h
Temperature: 57.0°C
Temperature: 23.0°C
Voltage: 13.970 V
000777 - Cylinder 9
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154194 km
Time Indication: 0
Date: 2015.11.18
Time: 20:11:41
Freeze Frame:
RPM: 749 /min
Load: 25.5 %
Speed: 15.0 km/h
Temperature: 57.0°C
Temperature: 23.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154194 km
Time Indication: 0
Date: 2015.11.18
Time: 20:33:32
Freeze Frame:
RPM: 679 /min
Load: 28.2 %
Speed: 8.0 km/h
Temperature: 57.0°C
Temperature: 30.0°C
Voltage: 13.716 V
000775 - Cylinder 7
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154235 km
Time Indication: 0
Date: 2015.11.19
Time: 13:10:46
Freeze Frame:
RPM: 738 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 50.0°C
Temperature: 18.0°C
Voltage: 14.224 V
