Monday,22,June,2020,17:19:15:01884
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WAUDN74F98N118618 License Plate: 1TNG64 6/22/2020
Mileage: 316450km-196632mi Repair Order: Not Again
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 1E 36 37 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUDN74F98N118618 Mileage: 316450km-196632miles
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
07-Control Head – Status: OK 0000
0F-Digital Radio – Status: OK 0000
15-Airbags – Status: OK 0000
17-Instruments – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
42-Door Elect, Driver – Status: Malfunction 0010
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: OK 0000
65-Tire Pressure – Status: OK 0000
76-Park Assist – Status: OK 0000
Address 01: Engine (BXA) Labels: Redir Fail!
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L V10/4V FSI ª0010
Revision: 5HH02— Serial number:
Coding: 01050009190F0160
Shop #: WSC 08259 444 84947
VCID: 2313E96997D58DD36E9-8076
13 Faults Found:
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:01
Freeze Frame:
RPM: 199 /min
Load: 51.0 %
Speed: 0.0 km/h
Temperature: 106.0°C
Temperature: 42.0°C
Absolute Pres.: 990.0 mbar
Voltage: 10.668 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:01
Freeze Frame:
RPM: 199 /min
Load: 51.0 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 10.668 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:01
Freeze Frame:
RPM: 199 /min
Load: 51.0 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 10.668 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:01
Freeze Frame:
RPM: 196 /min
Load: 49.0 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 10.668 V
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:02
Freeze Frame:
RPM: 180 /min
Load: 49.4 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 10.414 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 9
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:03
Freeze Frame:
RPM: 178 /min
Load: 49.4 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 10.414 V
009217 - EVAP Leak Detection Pump Control Circuit
P2401 - 002 - Short to GND - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:11
Freeze Frame:
RPM: 429 /min
Load: 54.5 %
Speed: 0.0 km/h
Temperature: 41.0°C
Voltage: 11.938 V
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:05
Freeze Frame:
RPM: 1566 /min
Load: 36.8 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 46.0°C
Voltage: 11.303 V
000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0051 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:05
Freeze Frame:
RPM: 2341 /min
Load: 70.6 %
Speed: 0.0 km/h
Temperature: 46.0°C
Voltage: 11.430 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0031 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:06
Freeze Frame:
RPM: 2717 /min
Load: 32.9 %
Speed: 0.0 km/h
Temperature: 46.0°C
Voltage: 11.811 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:37
Freeze Frame:
RPM: 1268 /min
Load: 17.6 %
Speed: 17.0 km/h
Temperature: 99.0°C
Temperature: 47.0°C
Voltage: 13.081 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:37
Freeze Frame:
RPM: 1220 /min
Load: 18.8 %
Speed: 16.0 km/h
Temperature: 99.0°C
Temperature: 47.0°C
Voltage: 13.081 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316459 km
Time Indication: 0
Date: 2020.06.22
Time: 16:16:39
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 95.0°C
Temperature: 72.0°C
Voltage: 12.065 V
Readiness: 0010 1101
Part No SW: 4F5 910 156 F HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0020
Revision: --H04— Serial number: 0119625
Coding: 0000002
Shop #: WSC 02335 785 00200
VCID: 2B030149FF054593D69-807E
1 Fault Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 316447 km
Time Indication: 0
Date: 2020.06.22
Time: 13:06:57
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
VCID: 313F1321DD292F43EC5-8064
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 10
Reset counter: 171
Mileage: 316447 km
Time Indication: 0
Date: 2020.06.22
Time: 13:06:55
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x00A2
Hex Value: 0x0028
Hex Value: 0x0182
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0040
Revision: 09010701 Serial number: 10601601012114
Coding: 0000015
VCID: 2411EA7592DB8AEB173-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H46 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
No fault code found.
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 D HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 361DS087521658
Coding: 0010003
Shop #: WSC 01814 444 69275
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001836152
Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
Subsystem 4 - Serial number: 010535ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
8 Faults Found:
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:01
Freeze Frame:
RPM: 202 /min
Load: 49.4 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 10.668 V
000268 - Mass Air Flow Sensor (G246)
P010C - 002 - Signal too Low - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:02
Freeze Frame:
RPM: 177 /min
Load: 49.4 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 10.414 V
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:15:03
Freeze Frame:
RPM: 177 /min
Load: 49.4 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 10.287 V
004764 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129C - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:04
Freeze Frame:
RPM: 1573 /min
Load: 34.1 %
Speed: 0.0 km/h
Temperature: 46.0°C
Voltage: 11.303 V
012800 - Oxygen (Lambda) Sensor B3 S1; Heating Circuit
P3200 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:04
Freeze Frame:
RPM: 2340 /min
Load: 70.6 %
Speed: 0.0 km/h
Temperature: 46.0°C
Voltage: 11.430 V
012848 - Oxygen (Lambda) Sensor B4 S1; Heating Circuit
P3230 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:04
Freeze Frame:
RPM: 2340 /min
Load: 70.6 %
Speed: 0.0 km/h
Temperature: 46.0°C
Voltage: 11.430 V
012821 - Oxygen (Lambda) Sensor B3 S2; Heating Circuit
P3215 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:37
Freeze Frame:
RPM: 1269 /min
Load: 17.6 %
Speed: 17.0 km/h
Temperature: 99.0°C
Temperature: 47.0°C
Voltage: 13.335 V
012869 - Oxygen (Lambda) Sensor B4 S2; Heating Circuit
P3245 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 316448 km
Time Indication: 0
Date: 2020.06.22
Time: 13:25:37
Freeze Frame:
RPM: 1269 /min
Load: 17.6 %
Speed: 17.0 km/h
Temperature: 99.0°C
Temperature: 47.0°C
Voltage: 13.335 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7Q AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD020ND1
Coding: 0014161
Shop #: WSC 02325 785 00200
VCID: 2F3B1559CB1D39B3FA1-807A
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME3A00710AZ
Subsystem 3 - Serial number: 6342CSME3A007305X
Subsystem 4 - Serial number: 6352QSME5439223BG
Subsystem 5 - Serial number: 6362QSME582D3C23Q
Subsystem 6 - Serial number: 63734SME57140A09.
Subsystem 7 - Serial number: 63834SME4E371341$
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025080420380
Coding: 0012141
VCID: 270BFD79E3ED61F3321-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 984 HW: 4F0 920 984
Component: KOMBIINSTR. 0900
Revision: 00000000 Serial number: AYV41ZK7D
Coding: 2129206
Shop #: WSC 55433 000 104857
VCID: 6A8DC44D307F9C9BEDF-803E
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 171
Mileage: 316459 km
Time Indication: 0
Date: 2020.06.22
Time: 16:42:00
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B082168127
Coding: F5D5DEF7707A0600
VCID: 2D070F51C1114BA3C8D-8078
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046007 Serial number: AUZ5ZBH8315046
Shop #: WSC 00000 000 00000
VCID: 1869CE855E93DE0B8BB-804C
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FA361CD49DFC33C5-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 395BX087509814
VCID: 38292E053E53FE0BABB-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00-00000
Coding: 0052075
Shop #: WSC 02327 785 00200
VCID: 2C010255FA0B42ABDF3-8078
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 316440 km
Time Indication: 0
Date: 2020.06.22
Time: 09:59:59
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01099647600000
Coding: 4618389
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 171
Mileage: 136984 km
Time Indication: 0
Date: 2013.12.12
Time: 18:33:23
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000074438
Coding: 0000026
VCID: 2517F77199E173E300D-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000058758
Coding: 0012014
VCID: 5EE5989DFC37E03B017-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00-00000
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04—
Coding: 0008022
Shop #: WSC 02145 785 00200
VCID: 2019E66586C396CB73B-8074
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290FFB41F5F95783245-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394B1087867927
Coding: 0000002
VCID: 2E05085DCC1730BBF17-807A
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000027645
Shop #: WSC 00000 384 00290
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 0320910A33
Coding: 303030393135313035444C56413030333230393130413333
Shop #: WSC 12345 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900065892
Coding: 0062725
Shop #: WSC 00000 785 00200
VCID: 221DEC6D88CF84DB65F-8076
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000802140192
Shop #: WSC 12336 024 394758
VCID: 34311A35223B1A6B873-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J82205O
Coding: 1000204
VCID: 5DE79F91F131FB2318D-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0051754
