Hi everyone I’m new here but I saw some post with lots idea.
I have 2010 audi s4 dsg and my error is clutch 1 and 2 high pressure and I tried to do adaptation will failed all time for safety reasons.Before it was leaking oil from the safety port (small hole above the transmission connector which is for safety so the gear oil won’t mix with dtc oil) but I plugged that one and was checking the dtc oil if it will gets overfilled which it was and the clutch one started to slip and throw me a code for clutch 2 pressure high so I decided to remove the trans and replace the shaft seal.
So I bought the clutch friction plate to and replaced the metal plate were good.
Now I can’t do the adaptation and throws 2 codes for pressure clutch 1 and 2 and plus adaptive learning
The codes are p2789 adaptive learning at limit
And P17D7 clutch pressure to high
Checked all solenoid for resistance all are good little to high like .3 or .5
If anyone have any idea will be appreciated
