2005.5 4.2l errors: Multiple random misfires....
Hello all,
This is my first post on this particular forum. I purchased my 2005.5 S4 a little over a year ago. Yesterday I was on the highway going about 75mph when I started to feel a small shudder (as if the road had small bumps) and then I noticed the check engine light was on. I pulled over immediately, and at idle the car was missing quite obviously. I turned the car off and tried to restart it and it had a hard time starting and was missing so bad it couldn’t stay above 200 rpm. I shut the car off, and plugged my scanned in getting codes for random multiple misfires, misfire cylinder 4, misfire cylinder 6, and misfire cylinder 8. I called a tow truck and now the car is in my garage.
I am planning on checking compression in the misfiring cylinders tonight. Does anyone else have any advice? Any indication of what it may be? I’ve read anything from the MAF to timing chain guides/tensioners etc… I’m hoping it’s not the timing chain but have a feeling it may be.
Thanks for any input.
