2005 S4 B6 Sedan - Vibration at all RPM with no codes
Looking for some input and help…
Have a Canadian 2005 B6 S4 sedan with 160KM on the motor. The timing job was done 10k ago after tensioner failure. Put back together with all new parts and upgraded to JHM adjusters and RS4 guides. Plugs, coils, injectors o-rings were all done at the same time as well as valley pan gasket and sprayers. The intake manifold was taken apart and fixed as the flap was seized in the open position.
Driving home the engine developed a slight vibration after a pull to 5K. The vibration slowly worsened and luckily I was close to home and parked the car. In the driveway the car has a slight rough idle and vibrates at all rpms like it has a single cylinder misfire. Plugged in the Rosstech VAGCOM cable and found no codes whatsoever!
  • no CIL/MIL, no pending codes
  • no misfires and zero on all miss counters
  • short term fuel trim cycling between 0 and +/- 0.7 and longterm trim at 1.2
  • O2 voltages look good and don’t appear to be lazy
Mods:
JHM intake manifold spacers & TB coolant bypass
Fast Intentions cat back exhaust & piggie pipes.
That’s it!
What I have done so far:
  • swapped coils with a known good set and replaced the plugs
  • induced vacuum leak, ST & LT values changed to compensate
  • MAF test, hit 276 g/s
  • unplugged just about everything, no change
  • compression test, 150 to 160 across the board
  • Ohm test injectors, all 15 and within spec
What I found so far:
The only anomaly I found surrounds the knock sensor voltages while monitoring blocks 26 and 27. Bank 2 sensors all report .700v when idling and move almost in unison when increasing RPM. Bank 1 sensors are a different story. When at idle they look like this:
Cyl 1 - .468
Cyl 2 - .360
Cyl 3 - .500
Cyl 4 - .500
Increasing the RPM to 2000 results in a large gap between the 1-2 and 3-4
Cyl 1 - 1.4
Cyl 2 - 1.1
Cyl 3 - 1.7
Cyl 4 - 1.7
Watching on the graph there is a very noticeable gap on Bank 1 for cylinders 1 and 2 with 2 always lower than the rest. The only thing I can think of is moving the injectors around to see if the knock values move accordingly. That said there is no commanded timing adjustments shown on 21-24 measuring blocks.
Any help would be greatly appreciated!
