2007-2011 replacement(inner) intake gasket
Where can I find one. (part number) and what exactly is it called? Not talking about the gasket in between the heads and intake. I’m talking about the gasket between the 2 intake housing pieces. I took my intake in half to inspect the broken plastic in it. I done wanna reuse the same one and or use a gasket sealer.
07L 133 075 A
http://audirevolution.net/addons/albums/images/731703161.jpg
Thanks bit that’s the throttle body housing gasket. I need the one sandwiched in between the two intake plates. I’m opening it up and fix the plastic pieces problem.
There is no factory gasket. It is sealed with a bead of liquid sealant. I would recommend Reizosil.
https://www.ecstuning.com/b-victor-reinz-parts/timing-cover-sealer/703141410~vic/?gclid=Cj0KCQiAw5_fBRCSARIsAGodhk-4JtxTQOGBw3dfsgD_0B05vG_raff0XwDGjFTMlrqjvfE50wl-bFMaAl-EEALw_wcB
Unless there is a number on the gasket itself, I doubt you will find one.
The intake is a sealed unit. Any gasket inside is not going to appear on any parts list other than the bill of materials from the actual manufacturer.
I believe most people just seal them up with black rtv.
Thank you sir. Having people like you help with important info on this car is the best thing ever. Seriously thanks.
Hey thanks for the quick responses. You are a great help. You have slot of knowledge. I really appreciate it.
