I have the exact same issue! Will be interested to see what the solution is. I have no codes in VCDS. I will check my fuel trims as well. I have smoke tested my system and found no vacuum leaks.
I can feel the vibration in park, neutral, and drive while stationary. Much worse in neutral and park than it is in drive. When I’m in the 1900-3000 rev range, vibration has the same pattern no matter what gear I’m in. Builds up as I get to 2500 and then starts dying down as I approach 3000. From 1000-1900, it’s just a constant low vibration.
Today I also found that on a cold start, it’s especially bad when reversing. Feels like the car wants to lurch forward every half second. No issues reversing when it’s at operating temperature. No issues with the transmission shifting and no codes there either.
VCDS showed short term fuel trim while idling was mostly in the +0-5% range, but would randomly spike between +10-20% on both banks for a few seconds before going back down. Long term fuel trim was 2.7%. I’m also getting a code for random/multiple misfire and misfires across all cylinders. Just to be sure, I tested all the ignition coils (which I never replaced) in a friend’s 4.2 A6 and it ran perfectly fine. Gonna try getting it in for a vacuum line smoke test.
Also, is it normal that the engine won’t go past 6000 RPM while driving once the flaps have been locked? I did get a flashing CEL once I approached that range. I don’t recall anything mentioning that when I was reading up about locking the flaps, so maybe it’s related to whatever the issue here is?
Thanks for all your input so far, I appreciate it!
Feels better knowing I’m not alone! Do you also have busted flaps in the IM or is yours all good?
It is not normal to have the motor not go past 6000rpm. This would suggest you’re in some sort of limp mode. But that limp mode would be present if your car had to auto out of missfires. Meaning that you had so many missfires the counter reset.
Open vag com and log to see if the vibration is from missfires. I would take that on as the next step
Well i’ve searched a fair amount of time after a similar issue…
Stationairy misfires over all cilinders except for one… car ran great otherwise…
CEL once every two weeks for returning misfires… fuel trims in VCDS where good, no vacuum leaks visible when smoke testing… new injectors and coils and coil packs, you get the idea…
For me after all it was a cracked line more specific the line under the PCV back to the engine… after i changed this the car ran great again.
Yes I can’t stress enough that the tricky PCV system can have hair line cracks in it and thats not something that is going to show up on most smoke tests.
One thing to add to the tests is unplug the MAF and see if that helps. But I would check for missfires that would most likely be the vibration.
Also the crank pulley can start to fail and fall apart. That too might be worth checking.
Wouldn’t vacuum leaks that don’t show up through a smoke test still affect the fuel trims?
And for check the MAFs, do you just unplug both of them, go for a ride, and log misfires again? Or what are you specifically looking for with the MAFs unplugged?
i can’t explain why but the only fault i had was intemittend missfires at idle… perfect fuel trims nothing unusual…
What is the best way to check for these hairline cracks? I have looked over the hoses and not found anything previously by just looking at them, but is there a better way?
Just to expand on this issue:
Before the IM swap, it would go past 6000 without a problem. Using the IM with locked flaps, as the engine reaches around 5700 RPM and climbs to 6000, it’s similar to gradually bending a hose to stop the flow of water. The climb from 5700 to 6000 is slow and then it just runs out of breath. I may try swapping the old IM back on to see if that changes it.
First, we checked misfires with RPM and took it for a 15 minute drive. While idling at around 600 RPM, occasionally will get 1 misfire. Same thing staying under 2200 RPM. Normally accelerating from 2000-3000 RPM, I saw around 25-35 misfires. Beyond 3000 RPM, counter barely goes up. The party is in the 2500-2600 range. When staying in that range, the counter climbs by hundreds in a couple of seconds, every time. It’s also where the vibration is the worst.
We then went for another drive and checked misfires according to cylinders. Not much under 2200 and above 3000 RPM on any of the cylinders. Going from 2200 to 3000, cylinders 2, 6, 7, 8, 9, and 10 showed 1 or 2 misfires on the counters. Cylinders 1, 3, 4, and 5 showed between 3-10. The number of misfires on 1, 3, 4 and 5 rapidly grew between the 2500-2600 range.
The CEL did not flash at any point during the drive. Didn’t take it beyond 5000 RPM, but that’s the only spot where the CEL does flash. I might just pick up a cigar or something to do a vacuum leak test today, I’m becoming more and more convinced that’s where the issue is.
Best way is changing them
@dzow I dont like changing parts just for the sake of it, so will look into some other ways to test for leaks. That main PCV hose isnt cheap!
@GreetingsWench It is somewhat comforting to find someone who describes the exact same issues I am dealing with. Hopefully we can get to the bottom of this. I have a gutted intake manifold, so mine is in the short runner position. I can say that I have no issues with revving past 6K RPM. Mine takes off around there as that is around where the intake would go to the short runner and pulls all the way to redline. The one thing in common is that we both have IMs that have been messed around with.
One thing another member had mentioned that I havent got around to yet is looking at adapting the throttle bodies through VCDS? I have just received my cable to will look into how this is done this weekend. Apparently they might need this adaptation if they have been roughed up a bit in the IM removal/install. I am not getting my hopes up that that is the issue, but worth checking.
I disconnected the MAFs and car ran pretty much exactly the same. I also did a throttle body adaptation and it made no difference (@spencerprince car on, engine off, in VCDS go to Engine > Basic Settings > Group 060 > click ON and wait about a minute, then click OFF).
I did hear a loud hiss coming from the bank 1 side. I pinched the hose circled in the photo and the noise stopped. Did not change the idle or sound of the engine. No idea if the sound is normal, can’t recall if it’s always made that noise. I took the line coming from the brake vacuum pump off to check if it was dirty or broken but it looked fine.
I then took the oil cap off. There was a massive amount of suction keeping it down and engine began to stutter once it was removed. I did the same on a Q5 with a 3.2L V6 (no codes, car is in perfect running order). Did not feel any suction and there was no stutter with the cap removed. I put my old oil separator on and it was exactly the same. I’ve seen people on both sides of this, saying there should be lots of suction or there should be very little suction. I assumed there should be suction, but then I’ve got no idea why the other car has no suction.
Lots going on so here we go.
Best way to check PCV parts is to water test. submerge the part into water. Usually you can use an oil drain tray or pan. Submerge the part cap off one end and feed air into the other end (low pressure) don’t go crazy. You should see bubbles if there is a crack or leak.
Check the drain line going to the oil pan as well. Also make sure the oil separator diaphragm is good. If you feel really manly you can take it apart and see the diaphragm itself.
Always check fuel trims when this is happening.
The drain line is the one that was cracked on mine… cheap part that costed me a lot just to find it… if i would do it again i would immediately change it with the PCV…
Not sure what changed overnight, but the engine is now able to go up to redline. Still get a flashing CEL as I go past 5500 or so, but doesn’t feel restricted at any point. It seems to upshift a lot quicker in manual mode as well. Going to clear all codes and start fresh this evening, I’m looking in way too many directions at the moment
that’s it indeed
Got around to looking at my car this weekend. First step was looking at the fuel trims. I cleared the codes and looked at groups 032 and 033. In group 033, the values were hovering around 10% after the reset at idle. Is this high enough to conclude a vacuum leak?
And more of a general VCDS question, but is it normal for the “Adv measure blocks” to be greyed out for our car? My product is registered. Even when I go in thorugh the normal measuring blocks, I am unable to view the cylinder specific misfire counters, I believe these are MB 15, 16 and 17. Are any of you able to get into these? If so, I guess I need to follow up with Ross Tech.
I did do the Throttle body Adaptation and the Intake Flap Adaptation. I dont believe the Intake Flap adaptation worked because I have the flaps removed? Is there another one for the motors that control the swirl flaps?
Anyways, the car does seem to be running better after these adaptations. Will wait to hear back from the group on checking the misfire counters and the possible vacuum leak. If this is a possibility, I will water test the two PCV lines.
Which module are you checking for the cylinder specific misfires in? Misfire monitoring is carried out by the slave ECU (ie. engine 2)
This is why this forum is invaluable! I was definitely in ECU 1. Will check ECU when I get to use VCDS again later next week.
