2007 S6 phone help
I was trying to clear a code I was getting on my phone. My car is equipped with the phone dock in the armrest but I don’t have the cradle or phone the car had when new. So I was looking around vogcom and found a setting for installed phones. It had 3 options two were phones and the last was none. Since the car doesn’t have a phone I figured choosing the “none” would clear the code. I was wrong I still have the code below and now my phone will not connect to the car for calls. I haven’t been able to get back to a screen giving me the option to turn on the phone and the mmi just says no phone installed. Can anyone point me in the right direction?
Thanks
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 241110CD12D4791735F-8070
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 32
Mileage: 134750 km
Time Indication: 0
Date: 2018.08.06
Time: 19:46:09
Your coding is wrong.
Under coding it should be: 0010900
Try that first.
Thank you I will give that a shot when I get off tonight.
Thanks that cleared the code! After clearing that out I looked around again for the setting I messed up. Turns out I changed a setting in the “hidden” green menu so here is the path I took incase someone else does the same thing by mistake (green menu-Diag settings-Anpassung-Telephone make- I had none selected but needed Motorola for my phone to work correctly. Again thanks for the help.
