Time has come to dismantle the car, and move on with my life. I have loved this car and spent stupid money on it in parts, maintenance. I am underwater on the loan due to a very recent engine out service, and looking to break even. Car located in Lancaster PA. Let me know if you want something not on the list, as I couldn’t think of everything.
Clean 2007 Audi S6 (Light silver metallic body) shell with full black Sport interior, carbon fiber trim and goodies. 110k miles on body, was just inspected before crank failure. Pricing does not include shipping. Items for sale:
Exterior
-Aluminum Hood ($350)
-Aluminum Front Fenders ($250/each)
-Front bumper with DLR’s included. They are cracked but all work. Has had clear bra installed since new - $350
-Head Lights ($250/each)
-Tail Lights (250/set)
-Rear Bumper ($200)
-Trunk w/ badging - ($150)
-Doors($150 each)
-Door Mirrors ($250/set)
-Carpet ($150)
-Aluminum rear view mirrors ($300)
-Goodyear 18x245x45 runflat tires on ratty (no cracks, just curbed to hell) 18x8 rims, 8/32 tread on all 4 corners. No TPS.($800)
-Front Windshield
-Rear Windshield
Motor Bolt Ons
-JHM Intake Manifold ($2200)
-JHM Intake Spacers w/ Fasteners & intake manifold gaskets with 3k miles on them ($250)
-JHM Crank Pulley ($250)
-Both ECU’s with JHM 93 Octane Tune, and SAI delete option, 2 programmed keys, ignition switch ($1000)
-JHM SAI delete never installed (first person to buy 2 items gets this for free)
-JHM Oil bypass kit never installed (first person to buy 2 items gets this for free)
-ZF 6HP26 Transmission with JHM TCU Tune, and fresh Transmission Fluid filter change 3k miles ago. Shifts Very Strong. $1400
-Rebuilt Torque Converter with 0 miles on rebuild.($400) Still in box
-Custom 3” X-Pipe exhaust built by Redrun Exhaust in Ephrata. Stock up stream resonators, X-Pipe, Magnaflow mufflers and retention of OEM s6 exhaust tips for a stock look. Single piece / perfect fitment. Sounds perfect for a V10 daily. SOLD
-HPFP’s ($150 each)
-Fuel Lines (30/each)
-Throttle Bodys ($400 / set)
-(2) K&N Air filters ($100 / set)
-Starter ($150)
-Heads ($800 / set)
-Water Pump (3k on unit) ($400)
-Power Steering Pump (3k on unit) ($500)
-Alternator ($200)
-6/8 new O2’s with only 3k miles ($50/each)
-Radiator ($150)
-Radiator fan assembly ($750)
-Oil Cooler ($100)
-Front Sway bar $150
-Axels with wheel bearing, dust shield and steering knuckle($1000 /set)
-Mahle full front control arm set ($500)
-Shocks & Springs (200 / front set)
-Coil Packs ($100) (Sold)
-1 degree cooler spark plugs ($50 / all 10)
-Hitachi injector set with injector seal kit (Under 40K Miles) - $900
-Original set of injectors I pulled off the car when replaced them with the above injectors - ($500)
-Felt wheel liners
-Driveshaft
-Fuel tank sender (Sold)
-Power Steering (3k on unit) ($500)
-Power Steering Cooling Line (Sold)
-PCV Breather Hose (3k on unit) ($150)
-PCV valve - $125
-Engine Mounts (around 15k miles on them) ($600/set)
Brakes (20k miles on the below components) get everything for $1000
-Adam Rotors high carbon custom rotors on all 4 corners
-S6 brake calipers with caliper covers
-Upgraded Stainless Steel brake Lines on all 4 corners
-Stoptech pads
Interior
-Black full S6 seat set with reupholstered front seat bottoms. ($1200)
-Gray Weathertech liners for all passengers ($120)
-Spare Comfort A6/S6 seat set (fronts and rear bench) w/ heater elements for rear. Black leather no cracks. ($400)
-Instrument Cluster ($300)
-Headliner
-MMI Screen
-MMI center console controls ($250)
-Middle dash vents smashed to shit, dont ask.
-Carbon fiber set ($350 (typical cracked passenger dash part))
-S6 Steering wheel w/ paddles ($150)
-ECU Wiring Harness with Fuse Holders (Sold)
-Door cards ($100 / door)
-Bose speaker set and Amp
-Various control modules
-Dash
-Battery
-APR Cheetah Cable EM100009 ($120)
Text me at 717-286-8618.
