This is in regards to an old post i made. I just lost contact with the guy i was originally talking to on my original post.
Im just wondering if there is a way or method of snapping to rock back in place without removing the second layer of the head (that bolts down the camshafts). probably a stupid question but worth asking because removing it going to be a b*tch. Look like most people would have to remove the engine to get to the back bolts where the camshaft gears are. Plus i dont have the replacement gasket.
Here is where we left off on the original post:
hey how did you put the rocker back on? Mine popped off like yours and was sitting in the bottom of the head.
Quote from: eddiedellz on October 08, 2018, 10:54:52 AM
Quote from: jonathanholik on October 07, 2018, 11:04:49 PM
Quote from: eddiedellz on October 07, 2018, 03:00:36 PM
I just went through this. Just finished putting the car back together. Pull the valve cover and inspect the rocker on that valve. I had the rocker pop off. but also the exhaust cam spin.
wow small world huh? Im happy you shared and glad you told me to check the rocker. was the plastic stuck in your valve too and was it causing it to misfire?
Yes! I had a piece of intake manifold plastic holding the valve open. But when i pulled the valve cover i had damage not saying you will though. Also you need a special socket to spin the motor by hand.
