Replaced all coils, spark plugs, cleaned fuel injectors. I have a misfire. Its pretty bad on cold start but once its warmed up it runs better. p0355 means cylinder 5. so i replaced that same coil twice( thought the coil was possibly a dud) but problem still persists. Oh and BTW I can start my car without pressing the brake pedal and turning the key. and the dome lights flicker alittle bit while car is running. where the heck is my misfire coming from?
If the plugs, coils, and injectors are good, then you’re left with everything before that - ECU, battery, intake, fuel pump/filter. The only thing that might likely not be systemic is the ECU for whatever reason. I’m sure others can provide better insight, but thats my 30 second analysis.
Thanks for you quick reply man. What about the turning car on without pressing the brake? Have any idea?
