I have been cleaning up my 2008 S6 and learning how to use the measuring blocks.
The car runs really well, but I am getting a CEL and decided to look into it.
I am including a fill scan with the cam adaptations included at the top of the log file.
I am reading that both chains are worn very badly -20 and + 20 on both sides.
It also seems to show that bank 2 exhaust cam adjuster is not moving.
That seems really streached for an engine that runs so well. I get the adjuster, but I want to verify what I see…
Thnx in advance
Address 11: Engine II (4F1 910 562 A)
17:56:10 Group 092
600 /min RPM
28.2 % Load
20.0°KW Idle Stabilization
17:56:10 Group 098
640 /min RPM
4.7 % Load
-22.0°KW Idle Stabilization
-22.5°KW Idle Stabilization
17:56:22 Group 092
2480 /min RPM
27.5 % Load
17:56:22 Group 098
2440 /min RPM
74.9 % Load
13.5°KW Idle Stabilization
-23.5°KW Idle Stabilization
17:56:28 Group 092
2480 /min RPM
26.7 % Load
1.5°KW Idle Stabilization
17:56:28 Group 098
2440 /min RPM
74.9 % Load
-23.0°KW Idle Stabilization
Address 01: Engine (4F1 910 562 A)
17:57:22 Group 090
640 /min RPM
4.7 % Load
17:57:22 Group 091
640 /min RPM
4.7 % Load
21.5°KW Idle Stabilization
17:57:38 Group 090
2640 /min RPM
4.7 % Load
17:57:38 Group 091
2640 /min RPM
4.7 % Load
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 13 15 16 17 19 1E 36 37 42
46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUDN94F48N141963 Mileage: 202800km-126014miles
05-Acc/Start Auth. – Status: Malfunction 0010
07-Control Head – Status: Malfunction 0010
08-Auto HVAC – Status: Malfunction 0010
09-Cent. Elect. – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
13-Auto Dist. Reg – Status: OK 0000
15-Airbags – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
55-Headlight Range – Status: Malfunction 0010
56-Radio – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
65-Tire Pressure – Status: Malfunction 0010
76-Park Assist – Status: Malfunction 0010
77-Telephone – Status: Cannot be reached 1100
Address 01: Engine (BXA) Labels: Redir Fail!
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L V10/4V FSI ª0010
Revision: 5HH02— Serial number:
Coding: 01050009190F0260
Shop #: WSC 08144 444 67893
VCID: 2310E6B7C7D6A613F20-8076
VINID: 9D19547891161087811012460C858AC62E
3 Faults Found:
008569 - Bank 2; System Too Lean off Idle
P2179 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 202788 km
Time Indication: 0
Date: 2022.03.23
Time: 19:38:31
Freeze Frame:
RPM: 2531 /min
Load: 23.9 %
Speed: 53.0 km/h
Temperature: 78.0°C
Temperature: 19.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.478 V
009237 - Oxygen (Lambda) Sensor B2 S1 Voltage too Low / Air Leakage / Sample Error
P2415 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 202794 km
Time Indication: 0
Date: 2022.03.23
Time: 19:53:19
Freeze Frame:
RPM: 636 /min
Load: 18.0 %
Speed: 0.0 km/h
Temperature: 100.0°C
Temperature: 57.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.351 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 202806 km
Time Indication: 0
Date: 2022.03.24
Time: 18:51:04
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 55.0°C
Temperature: 23.0°C
Voltage: 12.065 V
Readiness: 0010 1001
Part No SW: 4F5 910 156 F HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0020
Revision: --H04— Serial number: 0122511
Coding: 0000002
Shop #: WSC 02145 785 00200
VCID: 2B000E97AF066E534A0-807E
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
VCID: 313C1CFF8D2A048370C-8064
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H10 0050
Revision: 07020801 Serial number: 10602001054997
Coding: 0000007
VCID: 2412E5ABC2D8A12B8BA-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H46 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
1 Fault Found:
01176 - Key
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 202741 km
Time Indication: 0
Date: 2022.03.21
Time: 15:48:34
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 D HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 361DM087521742
Coding: 0010003
Shop #: WSC 02335 785 00200
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001039906
Subsystem 3 - Serial number: 0102.04.080000000100010968ÿ
Subsystem 4 - Serial number: 010968ÿ
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 202685 km
Time Indication: 0
Date: 2022.03.19
Time: 20:12:38
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030348066
Coding: 0536618
VCID: 1C62DD4BFAA899EB33A-8048
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 181
Mileage: 202685 km
Time Indication: 0
Date: 2022.03.19
Time: 20:12:44
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0115122
Shop #: WSC 33523 999 00003
VCID: 303A19FB86200D8B7F2-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0210
Coding: 00064784
Shop #: WSC 33523
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 33523
1 Fault Found:
02746 - Bulb for Daytime Running Light; Right
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 202684 km
Time Indication: 0
Date: 2022.03.19
Time: 20:12:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 2708F2A7BFEE4A33AE8-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7H0313724
Coding: 0000100
Shop #: WSC 00000 000 00000
VCID: 2F381A879B1E1273668-807A
2 Faults Found:
16347 - Control Module - EEPROM Error
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 211
Mileage: 202100 km
Time Indication: 0
Date: 2022.02.26
Time: 09:34:13
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 181
Mileage: 202685 km
Time Indication: 0
Date: 2022.03.19
Time: 20:12:50
1 Fault Found:
000036 - Bank 2: Camshaft B (Exhaust)
P0024 - 004 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 202787 km
Time Indication: 0
Date: 2022.03.23
Time: 19:34:37
Freeze Frame:
RPM: 1433 /min
Load: 17.6 %
Speed: 30.0 km/h
Temperature: 105.0°C
Temperature: 57.0°C
Voltage: 14.351 V
Address 13: Auto Dist. Reg Labels: 4F0-910-561.lbl
Part No SW: 4F0 910 561 C HW: 4F0 907 561 B
Component: ABSTANDSREGELUNGH02 0020
Revision: -------- Serial number: 00000000000000
Coding: 0041118
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7R AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD020T71
Coding: 0014162
Shop #: WSC 02325 785 00200
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME3A15411F1
Subsystem 3 - Serial number: 6342CSME3232351C-
Subsystem 4 - Serial number: 6352QSME5E521E13M
Subsystem 5 - Serial number: 6362QSME5F643E63Y
Subsystem 6 - Serial number: 63734SME6023497D2
Subsystem 7 - Serial number: 63834SME5B134041V
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90026080930235
Coding: 0012151
VCID: 2708F2A7B3EE4A33AE8-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 S
Component: KOMBIINSTR. M73 H22 0240
Revision: 00000000 Serial number: 733586F18
Coding: 2257388
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1000D082078267
Coding: F5D5DEF7717A0600
VCID: 2D04008F91126063544-8078
1 Fault Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 181
Mileage: 202685 km
Time Indication: 0
Date: 2022.03.19
Time: 20:13:39
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046007 Serial number: AUZ5ZBH8383161
VCID: 186AC15B0E90F5CB172-804C
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619CACBF9D4AF403A0C-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H51 0990
Revision: 00000000 Serial number: 395DO087513205
Shop #: WSC 03122 444 58724
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: 6Bc
Coding: 0051947
Shop #: WSC 02327 785 00200
VCID: 2C020D8BAA08696B43A-8078
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01111613410000
Coding: 4619293
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 187
Reset counter: 189
Mileage: 202099 km
Time Indication: 0
Date: 2021.12.19
Time: 14:52:24
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000088050
Coding: 0000026
VCID: 2514F8AFC9E258239C4-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000185409
Coding: 0011014
VCID: 5EE69743AC34CBFB9DE-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: Uˆb
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04—
Coding: 0008022
VCID: 201AE9BBD6C0BD0BEF2-8074
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000000
Shop #: WSC 08224 016 263172
VCID: 698CB49F657ABC4378C-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
4 Faults Found:
014 - Defective
Freeze Frame:
Fault Status: 01001110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 139
Mileage: 189866 km
Time Indication: 0
Date: 2020.08.14
Time: 16:56:52
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 178
Mileage: 201775 km
Time Indication: 0
Date: 2007.07.04
Time: 14:04:01
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00110010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 201775 km
Time Indication: 0
Date: 2007.07.04
Time: 14:02:42
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 201775 km
Time Indication: 0
Date: 2007.07.16
Time: 09:37:24
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394D 087891337
Coding: 0000002
VCID: 2E0607839C141B7B6DE-807A
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000069134
Shop #: WSC 08803 002 1048576
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 5199632834
Coding: 344630393135313035442056413035313939363332383334
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 4
Reset counter: 189
Mileage: 202766 km
Time Indication: 0
Date: 2022.03.21
Time: 23:08:25
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900071177
Coding: 0062725
VCID: 221EE3B3D8CCAF1BF96-8076
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 219
Mileage: 202225 km
Time Indication: 0
Date: 2022.03.17
Time: 14:20:51
Freeze Frame:
(no units): 43.0
Temperature: 22.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000804120081
Shop #: WSC 12336 024 394758
VCID: 343215EB723831AB1BA-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J8420AP
Coding: 1000204
VCID: 5DE4904FA132D0E3844-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06240810600149
Coding: 0021306
1 Fault Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 228
Mileage: 202689 km
Time Indication: 0
Date: 2022.03.20
Time: 14:25:28
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 02:17, VBatt start/end: 14.6V/14.4V)-----------
