"2008 S6" intro and project list
I am re-posting this from the Official C6 A6 New Member Profiles thread.
ok, I’ve been lurking here on and off for the last couple of years…time to post. I hear this is the board to be on for S6 owners.
I have a 2008 Quartz Gray S6 that I bought May 2014 with 61k miles after my '09 A4 was totaled when rear-ended. I’m a few weeks from the car rolling 100k miles…it’s been a long journey. I’ve really enjoyed the car (when not dealing with the typical DI-related engine issues), and wouldn’t mind keeping it going to 200k+ miles. I’ve endured the typical carbon and fuel injector struggles, but I think I’m finally coming out on the other side and am entering maintenance mode. There’s a lot of satisfaction in keeping a car going into high mileage, especially one as fickle as this. Wink
Work I’m planning for this spring/summer:
  • replace seized tensioner, serpentine belt, and idler pulley bearing; can someone tell me if there is a carrier lock service position for this car? where can I find steps to get at this tensioner?
  • possibly replace w/p “while I’m in there”
  • replace trans fluid and filter
  • replace front and rear diff fluid and transfer case fluid
  • give the front and rear suspension a good look-last mechanic mentioned upper control arm bushings need to be replaced; who knows where this will lead
  • took a piece of steel to the front bumper on the highway a few weeks ago; will have to repair that
Thought/opinions welcome. I still consider myself relative new to Audi although I’ve owned one as a daily driver since 2011. I’ve always maintained my own cars, but not too much with these so far. I plan on rolling my sleeves back up.
I’ve watched this board for a while. Doesn’t seem like there are any jerks here and everyone seems pretty helpful…two huge pluses in my book. I’m in my mid-forties with four kids, so I don’t need more drama in my life. :wink:
I know my way around air-cooled Porsche 911s very well, but not these “modern” Audi’s. I’ve mostly paid someone else to work on my S6 for the last 40k miles, but now that it’s 100k I feel like I need/can/should take over the rest of the way. With you guys at my side, I feel like I have a fighting chance.
To expand on the “carrier lock” reference above, I understand that some Audi’s have a service procedure where you can slide the radiator forward to get a few extra inches to access the front of the engine without removing the radiator (http://www.audiworld.com/forums/a6-s6-c6-platform-discussion-58/lock-carrier-service-position-2844067/) Apparently the C5 (and B bodies) had this feature, but trying to figure out if the C6 does too. If not, can someone point me to a thread or two that shows what I need to do to get full access to the tensioner and w/p?
I’m a bit hesitant to take the radiator out, only because I don’t know what’s involved and I’ve never worked on a cooling system (again, the air-cooled thing). But I had the front fascia off to replace the DRL, and that was no big deal…only have to go a little deeper for the radiator.
Also, wondering how big of a deal it is to replace the water pump. My prior mechanic had noted that there appeared to be coolant dried around the w/p indicating a prior leak. Since I have had to add a little bit of coolant to the reservoir over the last 15k miles, I think this is the place to start. (I’ve already replaced a cracked reservoir about 35k miles ago).
Chasing some sort of oil leak underneath too. Looks to be near the oil pan or at a sensor coming out of the transmission fluid pan. Engine oil level never seems to go down though over 10k miles. Going to clean the area up next weekend and see if I can’t get a better read on what’s going on over the next 1k miles.
Although this car design has some challenges (mostly related to DI, it seems?), the build quality seems really, really good. So, I think I could keep this car running forever if I can do the maintenance myself to keep the costs on the more reasonable side. After 3 years, I still love driving it and looking at it. ;D
