Hi everybody. My name is Jon, Ive owned my 2008 v10 s6 for about 3 years. I love it. Recently started misfiring out of no where. Couldnt even idle or drive anywhere. ran codes got multiple misfire code. Changed all the coils and spark plugs. same misfire ( although it I felt like it ran alittle bit better but close to the same misfire). ran codes again. the camhaft senosr code popped up. changed both sides and still the same.
At this point i figured the injectors where dirty and the carbon build up was causing all this. took off intake. doesnt look as bad as i thought it would in the intake ports. removing and cleaned all injectors with the carb cleaner can adapter and battery cable kit( fires the injector when connected to a power source)
BUT…
After very close inspection of the valve port area. One of my valves is stuck open by a broken piece of plastic or metal ( looks more like plastic). I wish i knew where it came from. Ive been trying to pry it out but its stuck in there pretty tight.
So, my question to anybody that has experience is. Could I just carefully grind it or cut it out( i know some of the pieces will fall down in the motor bit will be using a shop vac while doing the grinding to catch most of it.
So, on that port that valve is stuck open and the other one is closed. to my knowledge they are both supposed to be in the same position (both open or closed) since all the other port valves are. so, after removing the piece, will the valve go back to its normal position( releasing the tension on the valve spring) or am I just screwed and I gotta remove the whole head and replace the valve? it does not look bent…
This is my first post on here. so any help will be much appreciated. this has been a nightmare for me.
thank ya’ll
-JoN-
