Hey guys… sorry to bring an old thread up but I’ve got some more information about this topic.
Quick recap: Was getting random rich/lean codes from bank 2 - both upstream & downstream sensors (o2 sensors assigned to US passenger side, cylinders 4 & 5). Went through and did carbon cleaning, along with a new intake, new injectors from JHM, new coils and plugs. After doing this unfortunately the codes still come up, and are in fact preventing the car from passing emissions because the drive monitors cannot be set.
With that being said, the feedback I got from the indy shop was that the sensors appear to be working correctly as they can get data from them and they respond accordingly, but they believe something weird might be going on within the ECU that is preventing the drive monitors to be set. I took the car to Audi to verify whether or not the updated software had been installed that addressed some o2 issues on our cars. Unfortunately the update had already been installed and they too said they can see data coming from the sensors, however recommend swapping out the o2s.
Anyone have any suggestions as to what direction to go next? I’d just hate to go through the trouble of dropping the engine, swap sensors only to have the same issue again.
Other things I’ve tried:
Swapped MAFs from side to side - combined output at WOT seems to be around 310g/s, which is maybe 10% lower than it should be (could this be causing issues on just one single bank of o2s?)
Swapped coils and plugs from 4 and 5 and moved them to 3 and 4 - no change
Smoke tested crank case and addressed all vacuum leaks
Latest code I’ve pulled using vagcom:
008600 - Oxygen (Lambda) Sensor B2 S1
P2198 - 002 - Signal too High (Rich) - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 181092 km
Time Indication: 0
Date: 2018.06.19
Time: 18:46:23
Freeze Frame:
RPM: 2012 /min
Load: 83.1 %
Speed: 73.0 km/h
Temperature: 64.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.335 V
Readiness: 0100 0101
