Hey guys!
Quick intro here first: I was a long time member over at AudiForums in the A6 subforum and would try to help fellow C5’ers out whenever I had the time. I had an 03 A6 2.7T and just recently traded her in for an 08 S6. It was hard letting her go given how much time and work I had put in to her, but it was only a matter of time before a turbo went and I would be stuck with dumping in several grand worth of parts and several weekends of time pulling the engine and doing the install. So I did what any sane Audi enthusiast would do and buy an even more expensive-to-maintain beast such as the 5.2 V10 ;D
I took the car to go get inspected at my local indie shop who specializes on all German makes and they come back telling me it’s a faulty O2 sensor and the engine needs to be dropped. However I’m not convinced that is the case. Take a look at the most recent set of codes I pulled today from the car:
It is also important to note that the paperwork the shop gave me also indicated that cylinders 4 & 8 were also producing sporadic misfires. Also, at the time of the above scan with VCDS all monitors were set and complete. They have yet to re-set given it has not gone through a complete on/off cycle as the car was hot when cleared by me.
I have identified a taped up PCV hose on the driver’s side cylinder head (Previous owner/shop obviously broke it) which is causing a slight vacuum leak, along with a fairly significant vacuum leak from the oil separator (I pulled the oil fill cap off and heard the loud wooshing of air from the oil separator).
My question is am I on the right track here that this random lean/rich codes are attributed to the vacuum leaks and not a fouled up O2 sensor? I see a clear pattern here that everything is occurring on bank 2, so at this point I do not think their diagnosis of an engine drop is correct.
And if it is well, there might be a good chance I’ll put together a detailed DIY on removing the 5.2 ;D
Looking forward to any help and also looking forward to being able to return the favor to the 5.2 community here!
