Okay so here’s what happened I bought a sprint blue s6 with a major oil leak, it seems that after driving the car hard it leaves a small puddle under the front of the car. I have replaced the following already and it’s still leaking!! I did the oil cooler seals, the balance shaft cover seals inner & outer, I replaced the filter housing gasket once and then did it again but with a new filter housing the second time, a new PCV valve, a new valley cover gasket (pcv cover), It appears the oil is collecting on the metal coolant pipe that goes from the driver to passenger side and dripping down. I cannot seem to understand where it could possibly be leaking from, the valve cover gaskets and VVT solenoid gaskets are also new. If anyone has any ideas please let me know I’m so lost on what could be leaking as the front crank seal looks to be okay.
Valve covers could be warped and leak anyway, or the head griddle could be leaking as well. Plus the timing chain covers on the heads
