2011 Audi S6 voltage good, car won’t crank
Hi guys. I have a 2011 S6. Voltage good, battery only a year old. Just had the alternator replaced. The cars lights will turn on but the car just won’t crank at all, even if I try to jump it. Does anyone have ideas?
The car also has DCT/ABS codes that I think may be related on OBD11 as well as a TPMS that won’t clear. I pasted the log below
OBDeleven vehicle history log
Date: 2024-10-07 01:26:12
VIN: WAUBNAFB9BN042338
Car: Audi S6
Year: 2011
Body type: UNKNOWN
Engine: BXA   kW ( hp) l
Mileage: 134920 km
Full scan
Control Units: 27
Fault count: 9
Control Units:
02 Transmission
System description: AG6 09E 5,2 FSI USA
Software number: 4F9910156C
Software version: 0010
Hardware number: 09E927156C
	Faults:
		No trouble codes found
	05 Keyless System
	System description: FBSAUDIC6 ELV   H05
	Software number: 4F0910852B
	Software version: 0130
	Hardware number: 4F0905852E
	Hardware version: 242ÿ
	Faults:
	09 Central Electrics
	System description: ILM Fahrer      H30
	Software number: 4F0910279AE
	Software version: 0390
	Hardware number: 4F0907279A
	Faults:
	15 Airbag
	System description: Airbag AU1042
	Software number: 4F0910655R
	Software version: 0200
	Hardware number: 4F0959655H
	Hardware version: H07
	Faults:
	0E Media Player
	System description: CDC-MP3-Alp
	Software number: 4F0035110A
	Software version: 0140
	Hardware number: 4F0035110
	Hardware version: H44
	Faults:
	17 Dashboard
	System description: KOMBIINSTR.
	Software number: 4F0920985H
	Software version: 0209
	Hardware number: 4F0920985H
	Hardware version: H09
	Faults:
	16 Steering Column
	System description: J0527
	Software number: 4F0910549A
	Software version: 0530
	Hardware number: 4F0953549D
	Faults:
	19 Gateway
	System description: GW-BEM 4CAN-M
	Software number: 4F0907468M
	Software version: 0035
	Hardware number: 4F0907468F
	Hardware version: H06
	Faults:
	36 Driver Seat
	System description: MEM-FS
	Software number: 4F0959760D
	Software version: 0064
	Hardware number: 4F0959760D
	Hardware version: H08
	Faults:
	42 Driver Door
	System description: TSG FA
	Software number: 4F0959793T
	Software version: 0361
	Hardware number: 8K0959793M
	Hardware version: H12
	Faults:
	4F Central Electrics 2
	System description: ILM Beifahrer   H14
	Software number: 4F0910280
	Software version: 0100
	Hardware number: 4F0907280C
	Hardware version: ---
	Faults:
	47 Sound System
	System description: BOSE G3 C6
	Software number: 4F0035223P
	Hardware number: 4F0035223P
	Hardware version: H01
	Faults:
	52 Passenger Door
	System description: TSG BF
	Software number: 4F0959792T
	Hardware number: 8K0959792M
	Faults:
	56 Radio
	System description: Radio U SIRIU
	Software number: 4G0035082
	Software version: 0052
	Hardware number: 4G0035082
	Hardware version: H51
	Faults:
	53 Parking Brake
	System description: EPB  CEFC0090   H05
	Software number: 4F0910801D
	Software version: 0090
	Hardware number: 4F0907801B
	Faults:
	72 Rear Right Door
	System description: TSG HR
	Software number: 4F0959795P
	Hardware number: 4F0959795P
	Hardware version: H11
	Faults:
	5F Multimedia
	System description: H-BN-NA
	Software number: 4E0035664B
	Software version: 0116
	Hardware number: 4E0035664A
	Hardware version: H49
	Faults:
	55 Headlight Regulation
	System description: AFS 1           H01
	Software number: 4L0910357B
	Hardware number: 4L0907357B
	Faults:
	62 Rear Left Door
	System description: TSG HL
	Faults:
	6C Rear View Camera
	System description: J772__Rearview
	Software number: 4F0910441D
	Software version: 0030
	Hardware number: 4L0907441B
	Faults:
	76 Parking Assistant
	System description: Parkhilfe 4-Kan H03
	Software number: 4L0910283B
	Software version: 0500
	Hardware number: 4L0919283B
	Faults:
	01 Engine
	System description: 5.2L V10/4V FSI    ª
	Software number: 4F1910562B
	Hardware number: 4F1907552B
	Faults:
			P165300 - Read DTC memory of
		ABS CM
			Intermittent
			P192300 - Check DTC memory of
		Engine Control Module (ECM) 2
			static
	03 Brakes
	System description: ESP8 quattro    H03
	Software number: 4F0910517AL
	Software version: 0060
	Hardware number: 4F0614517BA
	Hardware version:
	Faults:
			01826 - Steering angle sensor, voltage supply terminal 30
			Intermittent
	46 Comfort System
	System description: Komfortgeraet   H29
	Software number: 4F0910289N
	Software version: 0250
	Hardware number: 4F0907289N
	Faults:
			01134 - Alarm horn
			static
			02742 - Left brake lamp/turn signal bulb
			static
	11 Engine 2
	Faults:
		ABS CM
			Intermittent
	4C Tire Pressure
	System description: J793  RKA+      H03
	Software number: 4F0910274B
	Software version: 0110
	Hardware number: 4F0907274
	Faults:
			01316 - Brake control module
			static
			00778 - Steering angle sensor
			Intermittent
	08 Air Conditioning
	System description: KLIMABETAETIGUNGH30
	Software number: 4F0910043B
	Software version: 0080
	Hardware number: 4F1820043AL
	Faults:
			00797 - Sunlight photo sensor
			static
Does it take any current when you try to crank it? If it does, your starter is most likely jammed. If it doesn’t there is a wiring issue. If the alternator was replaced just now, i’d look around it for something disconnected.
