2012 a8l alternator in 2008 s6?
Just wanted yalls advice on this question. Will a 2012 a8 4.2 alternator work in a 2008 s6. 5.2 ? Voltage and amps are the same as well as connectors. I don’t see why it wouldn’t be an issue other than removing the different coolant connectors and replacing them with the originals from the old one( becuz those are different )
it looks like they are different part numbers and have different mounting bracket patterns
2012 A8 alternator: https://www.audiusaparts.com/auto-parts/2012/audi/a8-quattro/base-trim/4-2l-v8-gas-engine/electrical-cat/alternator-scat
2008 S6 alternator: https://www.audiusaparts.com/auto-parts/2008/audi/s6/base-trim/5-2l-v10-gas-engine/electrical-cat/alternator-scat/?part_number=07l903805h
They have the same mounting styles though. The only thing different is where the positive wire mounts and the connector is located. I just don’t see why it wouldn’t work. I’m asking because I found a barely used alternator for 95 dollars. Cheapest reman I seen was 250 plus tax and core ( all that bullshit extra shit )
