VIN: WAUZZZ8V8E1035188 License Plate: AO14 TBZ
Address 01: Engine Labels: 06K-907-425-V1.clb
Control Module Part Number: 8V0 906 259 HW: 06K 907 425 A
Component and/or Version: 2.0l R4 TFSI H09 0006
Software Coding: 0A1D00322426010B2004
Work Shop Code: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0218V0906259 001008 (AU37)
ROD: EV_ECM20TFS021_AU37.rod
VCID: 7DF14CF3ECF1676E60-8028
5 Faults Found:
15446 - Blocking Valve for Coolant (N82)
P1889 00 [032] - Open or Short to Ground
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 101480 km
Date: 2021.04.22
Time: 13:35:00
Engine speed: 719.00 /min
Normed load value: 14.1 %
Vehicle speed: 0 km/h
Coolant temperature: 53 °C
Intake air temperature: 28 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 14.355 V
Unlearning counter according OBD: 27
Engine: operating status: IS
STATE_LS_SAE[1]: CL
T_AST_SAE: 69 s
MAP_MES_SAE: 46 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.114 V
FAC_TPS_1_SAE: 14.062500 %
FUP_H_SAE: 10860.0 kPa
15447 - Thermostat for Transmission
P19A2 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 101480 km
Date: 2021.04.22
Time: 13:35:00
STATE_LS_SAE[1]: CL
T_AST_SAE: 69 s
MAP_MES_SAE: 46 kPa
16452 - Implausible Data Received from ESP Control Module
U0416 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 101480 km
Date: 2021.04.22
Time: 12:33:10
Engine speed: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 49 °C
Intake air temperature: 32 °C
Voltage terminal 30: 12.500 V
Unlearning counter according OBD: 29
Engine: operating status: ES
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 102 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.998 V
FAC_TPS_1_SAE: 16.015625 %
FUP_H_SAE: 10370.0 kPa
14916 - Catalyst System; Bank 1
P0420 00 [237] - Efficiency Below Threshold
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 101489 km
Date: 2021.04.26
Time: 17:58:29
Engine speed: 1888.25 /min
Normed load value: 32.2 %
Vehicle speed: 79 km/h
Coolant temperature: 104 °C
Intake air temperature: 18 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.316 V
Unlearning counter according OBD: 40
Engine: operating status: PL
TEMP_CAT_UP_1_SAE: 681.2 °C
Cat. ageing: bank 1: actual: 1.547
LAMB_DELTA_I_LAM_ADJ[1]: -0.00006
Lambda probes actual: bank1: 1.0771
VLS_DOWN_SAE[1]: 0.080 V
T_AST_SAE: 530 s
16799 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 101480 km
Date: 2021.04.22
Time: 12:33:12
Engine speed: 1231.00 /min
Normed load value: 13.7 %
Voltage terminal 30: 11.738 V
ECU_STATE: SYN_ENG_IGK_ON
TOIL: 21 °C
Time since engine start: 0.2 s
T_ES: 30 min
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: operated
Cruise control switch actuation-Large increment: not activated
Cruise control switch actuation-Control component verified: No
STATE_ERR_ABC_PRED: 0
Readiness: 0000 0000
Dont know where can I start from as there were DTCs for Intake Manifold Runner and Camshaft advanced. Replacing Intake Manifold and Timing Chain those faults gone and after driving for a day these codes came up and Engine Light is on the dash. Now dont know where should I start from. Please advice. Thanks
