I’m back again with another installment of codes, this time due to a downshift. A few weeks ago I had the car randomly shutting off but after replacing the fuel pump all was well. This time I was on the interstate behind some slower traffic. They moved over and while in normal drive mode I activated the kick down and was met with an immediate violent jolt and the EPC light plus the transmission gear symbol and no forward power. I immediately pulled over, kept the engine running and put it in park, and pulled these codes:
Sunday,11,September,2022,09:38:09:03552
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WUAC6AFR1EA900756 License Plate:
Mileage: 85890km-53369mi Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
52 53 56 5F 6C
VIN: WUAC6AFR1EA900756 Mileage: 85890km-53369miles
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
04-Steering Angle – Status: OK 0000
06-Seat Mem. Pass – Status: OK 0000
13-Auto Dist. Reg – Status: Malfunction 0010
15-Airbags – Status: OK 0000
17-Instruments – Status: Malfunction 0010
19-CAN Gateway – Status: Malfunction 0010
1B-Active Steering – Status: OK 0000
22-AWD – Status: OK 0000
3C-Lane Change – Status: OK 0000
44-Steering Assist – Status: OK 0000
46-Central Conv. – Status: OK 0000
56-Radio – Status: OK 0000
5F-Information Electr. – Status: Malfunction 0010
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 F HW: 8T1 907 560
Component: 4.2l JHM93 / H04 0005
Revision: NAH04— CVN: A0D60F8A
Coding: 1A25003225C6080D3000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
ROD: EV_ECM42FSI011_AU48.rod
VCID: 3FDB49A0D7FD62F3DE9-806A
VINID: 9E54531915A20554490001C5189F67694E
1 Fault Found:
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [039] - -
[Transmission control moduleRead out DTC]
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 85890 km
Date: 2022.09.11
Time: 12:32:22
Engine RPM: 5460.50 /min
Normed load value: 29.8 %
Vehicle speed: 87 km/h
Coolant temperature: 90 �C
Intake air temperature: 38 �C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.970 V
Unlearning counter according OBD: 40
AFS dm: 361.1 kg/h
Mean injection time: 0.790 ms
Engine operating condition: full load
Engine operating condition-Test_Program_Channel 87: 7
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 H HW: 0B5 927 156 K
Component: 0B5 42 FSINAR H02 0005
Revision: --H02— CVN: 0000FABA
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 42DD4054A40F0F1BB17-8016
1 Fault Found:
18053 - Shift Fork 3
P284B 00 [167] - Stuck
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 85890 km
Date: 2022.09.11
Time: 12:32:22
Engine RPM: 4919 /min
Transmission input speed: 4919 /min
Transmission output speed: 711 /min
Engine torque: 516 Nm
ATF temperature: 68 �C
Accelerator pedal position: 100.0 %
Clutch status: Kupplung 2 kann Moment �bertragen
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 2C2D1A
VCID: 45D75B48B5A13823945-8010
2 Faults Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 234
Mileage: 85485 km
Time Indication: 0
Date: 2022.09.08
Time: 23:38:09
Freeze Frame:
Hex Value: 0x3D00
Hex Value: 0x4006
Hex Value: 0x1F23
Hex Value: 0x1DB1
Hex Value: 0x0000
01315 - Transmission Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 202
Mileage: 85890 km
Time Indication: 0
Date: 2022.09.11
Time: 12:32:22
Freeze Frame:
Hex Value: 0x5700
Hex Value: 0x4006
Hex Value: 0x1F0E
Hex Value: 0x23B3
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 HP HW: 8K0 907 064 GP
Component: BCM2 2.0 H13 0641
Revision: 00002001
Coding: 0D804040000000000000
VCID: 05579B48F521F823D45-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 0213000297786009
No fault code found.
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000073308733
Coding: 00037025002C00000000
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Component: KLIMA 3 ZONEN H04 0121
Revision: C1000000 Serial number: 01070920130333
Coding: 4802200000
VCID: 392F27B8C9594CC3E0D-806C
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000669599901
Coding:
06008091043C9FF2350040C3000039090F9CD388A2090221000008004000010200040034000000
Shop #: WSC 06325 123 12345
VCID: 7AADF8B48CDF87DBA97-802E
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels:
1KX-955-119.CLB
Component: WWS 260813 H15 0080
Serial number: SWF13080265273
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels:
8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21683964
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000001908130075
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R7H8803
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 2058C6C6000000000001
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 C HW: 8K0 907 561 C
Component: ACC3 H11 0100
Serial number: 00000000000000
Coding: 00333E
VCID: 323D1094142FBF9B217-8066
1 Fault Found:
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 202
Mileage: 85890 km
Time Indication: 0
Date: 2022.09.11
Time: 12:32:23
Freeze Frame:
Temperature: 28.0�C
Voltage: 14.08 V
Hex Value: 0x00BE
Speed: 86.4 km/h
Lateral Accel.: 0.72 m/s^2
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Component: AirbagVW-AU10 H47 0610
Serial number: 003KJDB0DEEL
Coding: 303343334830303030304A55304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4ACD68749C3FD75B797-801E
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R130000F55R
Crash sensor for side airbag: driver side:
Serial number: 6334MSME7E102C21C
Front Passenger’s Side Airbag Crash Sensor:
Serial number: 6344MSME7D624D5C-
Rear Side Airbag Crash Sensor (on driver’s side):
Serial number: 6352QSME464212466
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME0C36014EI
Crash sensor for front airbag: driver side:
Serial number: 63732SME69355644+
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME6D3604740
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20130904000290
Coding: 00003E
VCID: 51FF7F1871E9E48338D-8004
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 984 H HW: 8T0 920 984 H
Component: KOMBIINSTR. H35 0563
Revision: 00500000 Serial number: WVZ479W8E
Coding: 8BBF0100AF03D705020000
VCID: 44D1464CBE9B012B83B-8010
2 Faults Found:
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 226
Mileage: 84965 km
Time Indication: 0
Date: 2022.08.28
Time: 16:37:06
00438 - Fuel Supply Sensor 2 (G169)
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 226
Mileage: 84965 km
Time Indication: 0
Date: 2022.08.28
Time: 16:37:06
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z1382203E6
Coding: 80E3031600
VCID: 4CC16E6C96CBC96B4BB-8018
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 8060271203
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 226
Mileage: 84965 km
Time Indication: 0
Date: 2022.09.01
Time: 20:26:19
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.10 V
Count: 11
Bin. Bits: 00000
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 L HW: 8K0 907 144 L
Component: DYNAMIKLENK. H06 0720
Revision: 52001005 Serial number: --------------
Coding: 030000
VCID: 382922BCF25355CB1F3-806C
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 002008130001156
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F3B19E0079D92734E9-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000073362417
Coding: 001B7B25002C00000000
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0312809627
Coding: 010211
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_AU21.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0313484556
Coding: 010211
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C13224E00120102
VCID: 56F58C04580783BBEDF-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H38 0507
Revision: 00001000 Serial number: 0016772284
Coding: 010000010001
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 3431168CEEBBB1AB33B-8060
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0313984160
Coding: 0106029A00FAC10580B0003200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000719997
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA107414000004066090
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813019389503
VCID: 2D0703E80D11E0637C5-8078
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
VCID: 55F78B08450188A3E45-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 30000000100416
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 392F27B8C9D94CC3E0D-806C
Address 56: Radio ® Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156IY0D7900224
Coding: 020007010000000001
VCID: 2411E6CC5EDB212BA3B-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 D HW: 8R1 035 746 D
Component: H-BNT-NA H40 0738
Revision: -------- Serial number: 204I60D7597962
Coding: 150200020306A9EF75028B4E00000403140000000000000000
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130HU0D2815049
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001603557
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
1 Fault Found:
02067 - Optical Databus; Unpermitted Wake-Up Request
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 84965 km
Time Indication: 0
Date: 2022.09.01
Time: 20:22:33
Freeze Frame:
Voltage: 12.10 V
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08— Serial number: 525PA8-J3693IE
Coding: 1021008
VCID: 382922BCFE5355CB1F3-806C
End----------(Elapsed Time: 02:01, VBatt start/end: 14.5V/14.4V)-----------
The car was in limp mode but i logged these codes and then cleared them. I re-scanned and was left with the module 13 codes. I shut the car off, started it, and drove off. Within 10 seconds, the TPMS light shut off and i had non further issues except for cruise control not working and no codes. I stopped for gas in about 30 minutes and when i drove off again i had cruise control. 200 miles later i made it home with no more problems in any gear. I think something happened with shift fork 3 and the ECU really didnt like it. Also some of the codes were from a few weeks ago when i was dealing with the fuel pump. Ive got JHM stage 2 and the RMR trans cooler. My transmission has never had an issue before. I am aware of an Audizine thread that some of you guys authored roughly 2 years ago. What should my next step be? Drain the trans fluid and check/replace the filters? Check for shavings? Check solenoids? Run an adaptation? Wait and see? Also i couldnt figure out how to post the logged txt file that ive seen here before. It wont let me due to file type and i have a cheap HP laptop that only has VCDS on it that stays in the car.
